Hi all,
I'm currently trying to get MSN Messenger working correctly for my brother on his laptop and my PC, and it's starting to do my nut in. I believe I have successfully created the Virtual Server Rules and the Packet Rules to pass through the Firewall, and I have added the ports to the WindowsXP Firewall as well, but things like WebCam still do not work! If I disable the Firewall altogether it connects, but once enabled it is being blocked.
Here are the Virtual Server entries (as followed on Port Forward):-
x
And here are the Rules for the Firewall:-
x
The only thing I can think of as to why it does not work for my brother (but works for me) is the IP Address on the Virtual Server entries?! That IP is mine, he is x.x.x.101 however the Router won't let me assign the same ports but just change the IP as it says it is "Reserved" (obviously as it's already pointing to mine). How then can I create a Virtual Server for Messenger for me AND for the laptop? Or do I not need to??? I tried an IP of 0.0.0.0 but the Router would not accept that.
Please help! TIA!
x
x
Please help! TIA!
I shall try that when I can and see what happens.
