Please help !!
4 Feb 2007
Ive just installed GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency on an Asus P5N-E and the timings are showing as 5-5-5-31.
How can I get it to show the true figures of 4-4-4-12 ?
Thanks
You will have to go into the bios, under advanced (i think), chipset and change the top 4 settings to 4-4-4-12, then make sure your command per clock (CMD) is set to 2T.
Thanks for the replies.
I've changed the settings to 4-4-4-12 and that's worked.
You say change the vdimm to 2.1v, but on my bios the only values (I'm assuming vdimm is memory voltage?) near that are
2.013v
2.085v
2.178v
So which one would you recommend?
Thanks again
