please help
4 Nov 2009
Ok basically got a new cpu cooler and new case. Hoping to overclock a bit more now its cooled. I was hitting 3.2ghz before was was expecting to hit atleast 3.4ghz. I had a lot of problems once i had moved everything over i.e computer wouldnt start took me a whole day to fix it ( changed the voltages round and somehow working). Anyway now it was working i was like i will just hit it up to 3ghz to start because of the problems i had. But no i get nothing.... The screen just stays blank while the computer boots like ti did when i thought it was broke. Do you think i need more volts? seems like its lacking power. I once had to increase the voltages of the north bridge or something. Anybody know what it is called in bios?
What CPU/Mobo etc are you using?
I would suggest setting all the CPU settings back to stock and start overclocking from scratch.
