- 30 Sep 2009
- Beccles, Suffolk
Hello
Every so often I re install windows because of hardware / driver changes.
Not that uncommon.
So I backed up my data as usual
Put in my windows 7 disc as usual
Changed the bios to boot the dvd as usual
and then it displays the black and white bars to load up and is just getting stuck at the blue logo screen just after this before you enter your name and not going any further
I'm really confused and do not know what to do
I've tried changing the optical drive and it does the same thing
and I also downloaded another windows 7 home premium 64bit iso and burnt to a dvd just is case it was the dvd but it does the same thing.
If you have any ideas could you please help,
thankyou
Not that uncommon.
thankyou
