Please help :)
31 Aug 2011
Ok i dont wanna spend an arm and a leg on a graphics card... i wont be doing extreme GAMING i may play the odd call of duty, and battlefield yes ill be buying the new ones... :) but i dont wanna spend no more then £170-80 on a graphics card....
http://www.overclockers.co.uk/showproduct.php?prodid=GX-099-MS&groupid=701&catid=1914&subcat=1830
or
http://www.overclockers.co.uk/showproduct.php?prodid=GX-132-MS&groupid=701&catid=1914&subcat=1341
FYI: http://www.overclockers.co.uk/showproduct.php?prodid=GX-114-MS&groupid=701&catid=1914&subcat=1341 was gonna get this BUY DAMN it to expensive -_- and i dont want to go for ATI because i have read on countless forums whether it true or not... ATI are more suited for AMD then intel build... why IDK :) but your knolledge will be appreciated and i am very greatful :)
FYI: 650WATT powersupply, INTEL I5 2500K 3.30GHZ, AND 4GB DDR3 RAM :) forgot to add :) 22inch monitor aswell ^^
You could just get a standard OCUK 560ti mate.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-173-OK&groupid=701&catid=1914&subcat=1341 and try and overclock it, I'm not sure how well these overclock.
Or, spend £5 more than your budget and get the faster card - http://www.overclockers.co.uk/showproduct.php?prodid=GX-074-GI
The MSI is slighter slower than the gigabyte one that is cheaper as far as I can tell :)
I've never heard of ATI cards being more suited to an AMD rig, I've been using a Q6600 and my 6870 for ages and not had a problem. Many users here will be using intel chips and ati graphics as well.
You could go for a 6870 - http://www.overclockers.co.uk/showproduct.php?prodid=GX-040-HS&groupid=701&catid=56&subcat=1866 £132 and sell the games, you should be able to get £20 or so back.
Benchmarks for the two cards - http://www.anandtech.com/bench/Product/290?vs=330
Also, 460 vs 6870 benchmarks - http://www.anandtech.com/bench/Product/290?vs=313
Good luck :)
