Please help
4 Oct 2005
Herefordshire
Hi guys I am not sure where to post this.
I have got the OcUK Extreme" Intel Core i7 4770K @ 4.6GHz+ Extreme Overclocked Bundle.
the motherboard I chose :
Asus Z87 MAXIMUS VI FORMULA Intel Z87
Memory I chose
TeamGroup Vulcan Red 16GB
Cpu Cooler
Corsair h100i
Now I really only had one problem bsods, I worke dit out to be the asus ai suite 3 interfering with the overclock. so an easy fix was to uninstall it. all is well.
I then decided to upgrade my asus gtx 680 direct cu II graphics card.
I bought a Gigabyte-GTX780Ti-GHz-Edition
Now I am plagued by bosods lockups.
The steps I have taken
I thought it might be a airflow issue so I changed cases from my corsair 800d to Cooler Master Cosmos II Ultra I feel it has better air flow than the 800d. to the cosmos I added the extra fans to the side to cool the graphics card. I then checked the heat still the same it never ever gets hot nor the cpu even when gaming.
I re applied the overclock still the same random bsod or lockup.
This can be during a game just after a game or just watching youtube vids.
I have tried using just the certified NVidia drivers also the beta drivers.
I reaplied cpu thermal paste reseated cpu cooler.
Took out the memory and put it back making sure it was seated correctly
I took out my sound card Asus Xonar D2X 7.1 PCI-E
changed all of my sata leads to the new ones in the box
Cpu temps
when I am just looking around the internet non stressful computing my cpu is at 30c just below or just above.
When I am gaming it rises to around 46-50
Video card
when im doing non stressful stuff it hovers around 30-35
Gaming -it goes up to around 60
The temps look ok to me.
I have not overclocked my vid card whatsoever.
The kind or errors im getting
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 2057
Additional information about the problem:
BCCode: 50
BCP1: FFFFF16000316438
BCP2: 0000000000000000
BCP3: FFFFF960000E97A1
BCP4: 0000000000000007
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\021114-7207-01.dmp
C:\Users\Mark\AppData\Local\Temp\WER-19359-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?link...8&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
That is the last one I got.
The other one I got
021114-7831-01.dmp 11/02/2014 04:37:44 PAGE_FAULT_IN_NONPAGED_AREA 0x00000050 fffff100`c36eb558 00000000`00000001 fffff800`02ffa147 00000000`00000007 ntoskrnl.exe ntoskrnl.exe+75bc0 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.1.7601.18247 (win7sp1_gdr.130828-1532) x64 ntoskrnl.exe+75bc0 C:\Windows\Minidump\021114-7831-01.dmp 8 15 7601 293,088 11/02/2014 04:38:12
another one
021014-7191-01.dmp 10/02/2014 16:31:02 PAGE_FAULT_IN_NONPAGED_AREA 0x00000050 ffffff00`0108d950 00000000`00000000 fffff800`02e4ffc9 00000000`00000007 ntoskrnl.exe ntoskrnl.exe+75bc0 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.1.7601.18247 (win7sp1_gdr.130828-1532) x64 ntoskrnl.exe+75bc0 C:\Windows\Minidump\021014-7191-01.dmp 8 15 7601 293,096 10/02/2014 16:32:04
another one
020814-7519-01.dmp 08/02/2014 17:31:34 PAGE_FAULT_IN_NONPAGED_AREA 0x00000050 fffff684`0003a1b0 00000000`00000000 fffff800`02e7b55b 00000000`00000005 ntoskrnl.exe ntoskrnl.exe+75bc0 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.1.7601.18247 (win7sp1_gdr.130828-1532) x64 ntoskrnl.exe+75bc0 C:\Windows\Minidump\020814-7519-01.dmp 8 15 7601 293,088 08/02/2014 17:32:02
another one
020714-7176-01.dmp 07/02/2014 15:55:24 MEMORY_MANAGEMENT 0x0000001a 00000000`00041790 fffffa80`09f7bea0 00000000`0000ffff 00000000`00000000 ntoskrnl.exe ntoskrnl.exe+75bc0 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.1.7601.18247 (win7sp1_gdr.130828-1532) x64 ntoskrnl.exe+75bc0 C:\Windows\Minidump\020714-7176-01.dmp 8 15 7601 293,088 07/02/2014 15:56:19
020314-7347-01.dmp 03/02/2014 15:24:23 PAGE_FAULT_IN_NONPAGED_AREA 0x00000050 fffff0a0`04109d08 00000000`00000000 fffff800`02d9ef59 00000000`00000007 ntoskrnl.exe ntoskrnl.exe+75bc0 NT Kernel & System Microsoft® Windows® Operating System Microsoft Corporation 6.1.7601.18247 (win7sp1_gdr.130828-1532) x64 ntoskrnl.exe+75bc0 C:\Windows\Minidump\020314-7347-01.dmp 8 15 7601 293,040 03/02/2014 15:24:59
This is now making my pc life unpleasant and the amount of money I have spent is just making me miserable.
Can anyone throw any light to help me please
Both those BSOD codes are to do with the memory going by the OCUK BSOD code list.
0x1A = Memory management error. It usually means a bad stick of Ram. Test with Memtest or whatever you prefer. Try raising your Ram voltage.
0x50 = RAM timings/Frequency or uncore multi unstable, increase RAM voltage or adjust QPI/VTT, or lower uncore if you're higher than 2x.
Something else to try would be to flash the motherboard to the latest bios to rule out any incompatability. Download to a USB stick and then use EZ-flash in the bios. Do not use any windows flashing software (especially Asus's one). Write down your overclocking settings first as you will need to re-enter them after the flash.
What is your ram voltage set to? Iirc the vulcan reds at xmp are rated for 1.65v. Also try bumping your IOA, IOD and SA voltages to 1.15v. Leave cache/uncore at stock of 3900mhz for the time being.
Guys thank you for the replies.
I have totally reformatted my pc and put windows 8.1 pro(64 bit) so far cross fingers it has been fine.
As for faulty memory or setitngs voltages I bought the motherboard/cpu/ram as an overlcoked bundle surely the ram should have been tested for faults before leaving and reaching me ?
So I have not messed with any setting regarding the overclock
thanks for the replies so far.
EDIT: I did post in the customer services are of the forum, I think they ar eprety busy not realy a reply of note.
If you reformatted and seems well I would say it was a driver issue.
Glad it sounds like you sorted it.
I will point out I am pretty sure if you upgrade your BIOS on overclock bundles I don't think you are covered by support? Sure I had read that somewhere.
