PLEASE HELP!
4 Apr 2004
Manchester
Hi people.
So, like a total idiot I have decided to enter the secret menu on my LG 27GL850B. I then, in a panic when I saw it was not a place I should be and whilst trying to exit this menu, somehow managed to tell/trick my monitor into thinking it is a 27GL650F.
From this, my DVI wont work anymore, the monitor is showing desktop resolution to be 2560x1440 and the active signal resolution is 3840x2160.
Is there any way to set this back to normal? Like a hard factory reset? (the one in the menu doesn't work)
