Please I need a bit of help
17 Apr 2009
Norfolk
Hello to all of you overclockers.
I'm just at the point to know where to turn for help on my overclocking rig. I have done a few alterations to the bios fsb and thats about it, but from here on everytime I do something else I have problems so don't know what I'm doing wrong.:confused:.
My rig consist of:
Cooler master cosmos 1000 case
namless 850w psu
Asus P5K Premium
Intel dual core E8200 2.66GHz overclocked to 3.584GHz
4gb Corsair pc2-8500
HIS Radeon 4850 512mb memory
tuniq 120 cpu cooler
fans:
2 x 140 mm 61cfm exhust fans top
1 x 120 mm 55cfm exhust fan rear
2 x 120 mm 45cfm intake to gpu side panel
1 x 120 mm 61cfm intake bottom
1 x 120 mm 61cfm intake front
Disk storage
Samsung SP1614 160GB x 2
Samsung HD103UJ 1T
WDC WD1600YS 160GB
WDC WD5000YS 500GB
I was triying to make a raid 0 with the two Samsungs 160gb but I never had luck with the conections so I give up in the end so only one is the OS and the others storage. I would like to make a raid 0 still but I read that it does not improve speed so I don't know, something for the futeure I guess.
for now I need some one that can help me going foward with my overclock I want to reach 4GHz if possible.
Well I don't know what else to mention only that I would apreciated any response and help from any of you chaps. if you want to contact me bya email it's fine there it is
[email protected]
many thx
ReaperX
:D:D:D:D
Welcome.
Namless Power supply probably isn't doing you any favours when overclocking. I'd swap it for something decent (have a look a OCUK's range, nearly all of them are decent makes)
Yep, thats a relly nice build, but a 500w good brand psu would be much better than what you have. Maby try a corsair. Remember amps mean as much as watts
You don't mention what Vcore ur running, what ur north bridge volts are, basicly those are the 2 main things to raise when it won't go further.
Hey thx for the response, ;) I may have to do that I brought it coz I was in a budget, but I can estrech to something more substantial. in terms or Vcore and north bridge volts I'm a bit lost lol :confused: :D I'm new to this overclocking and build so I will have to try to find out.
But cheers I apreciate all your help. I will post some pics of this build as I go a long.:)
:D:D:D
thx ReaperX
Hi - I've just secured an E8200 on ebay to replace my 2180 (see sig spec), and I was wondering how high you'd managed to oc yours?
