Please idiot check me
20 Apr 2003
Gloucestershire
Hi All,
Having a moment and could do with a bit of advice.
I've recently bought a pair of Netgear WG602 wireless access points for an event (main and spare). Usual scenario is the venue provides either a single cat5 cable as the internet access or a DSL router.
My sudden worry is that its an access point not a router, is there any real difference?
So for the sake of agument, the access point is set up, with a single cat5 internet connection provided by the venue. SSID and Password etc are all sorted. Is it going to be happy with multiple laptop users connecting and sharing the connection?
I just noticed on the setup doumentation it alwys shows the access point connected after a router.
Thanks for the help,
E-I
If they aren't running NAT or providing a block of public IPs and you want to connect more than one device, it won't work.
Bugger, kind of what was worrying me... It may well be down stream of a router, but won't know until on site!
Time to buy alternatives I think!
Thanks,
E-I
You will either need your own NAT router, or you could set up one of your PCs to perform internet connection sharing (Turns the windows box into a NAT router, but you can still use the machine for other porposies). The windows machine would need 2 ethernet interfaces, one to connect to the internet, and one to a switch for the other machines.
Can you not ask them? I'd guess unless they need to keep things completely seperate that the feed is probably from a a router they have providing their internet feed.
Thanks for the replies,
Venues in Barcelona and from experience getting sensible information on broadband connection from some of our european freinds can be a little difficult.
Safest bet, new hardware! Just bought a pair of Netgear Wireless N cable routers instead. I'm not on site to troubleshoot any issues, so safest way I think.
Thanks for all the help guys!
E-I
