Please look I need your help!!
I had a quick google, doesnt seem like the easiest thing to find, if the auction sites are dead then your best bet is probably going direct to shuttle.
are you sure its your mobo thats knackered?
Look at shuttles website most manufacturers generally have a list of merchants which supply their products..
Thanks and yeh i'm sure its the mobo the pins in the socket are bent in desperite hope i tried bending them all back but with no luck.
