Please recomend a case for this bundle
Permabanned
30 Nov 2016
Thats in my basket just now, hoping to buy tomorrow.
I need a new case, dont want to spend the earth but not looking for gash either :) the spec for the bundle says ...
Please Note*
You will need to ensure that your computer case has enough room to fit a 240mm radiator in the roof or rear.
Performance can only be guaranteed when this bundle is used in conjunction with a quality 80+ Gold or better Power supply unit of suitable wattage for your whole system.
My basket at Overclockers UK:
Total: £872.98
(includes shipping: £11.10)
PS: Any other recommendations on bundle or PSU, please don't hesitate to say, would have preferred a black PSU, but not over worried on colour.
If you want the SuperFlower Leadex just go with the Gold rated one. A Platinum won't make hardly any difference on the old electricity bill (Might save you £1 per year).
Here are 3 other good units as well.
Total: £390.56
(includes shipping: £12.60)
Total: £390.56
Thanks, yes one of those will save a few bob, its to power my Titan X Maxwell and also 5 HD's and one OS SSD, would 750W be OK?
these are my favorite cases that match your description. Tried to get varying price-points in there. The in-win 303 has different rad mounting though (In some sort of chamber)
Total: £1,035.09
(includes shipping: £36.24)
Total: £1,035.09
Thanks, appreciated, think I'll go with the In Win 707 though.
If you are just running a single Titan X gpu then a 550W/650W would be enough. A 750W is usually needed for SLI setups.
Also why a Full Tower case if you are going with a Micro ATX Motherboard ?
Thanks for the re-assurance Lee, its more a cosmetic thing really, this will be my second back up gaming PC and it will sit beside my main PC that is a similar Full Tower under my corner desk, like lots of room in a case to work on too :)
Unless i missed something, is it not this bundle to be reduced...
Total: £633.90
ATX motherboard, not MATX.
EDIT.
Just noticed you are looking at large cases. Silly me for not reading the thread properly. :p
