22 Jun 2016 at 15:09 #1 lazkopat lazkopat Associate Joined 5 Feb 2013 Posts 51 Hello all, can someone recommend me a gaming setup as well as I plan to use the setup for virtual operating systems for testing. my budget is £1200 thanks
22 Jun 2016 at 15:11 #2 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare Hi. Is it a pre-built system or a diy one you a looking for. What about monitor, keyboard, OS etc
22 Jun 2016 at 15:14 #3 lazkopat lazkopat Associate OP Joined 5 Feb 2013 Posts 51 I would prefer to do it yourself system as that;s more appealing. keyboard monitor etc i shall buy at a later stage. cheers
22 Jun 2016 at 17:02 #4 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare My basket at Overclockers UK: 1 x Corsair Force LE 240GB 2.5" SATA 6Gbps Solid State Drive (CSSD-F240GBLEB)= £49.99 1 x Phanteks Eclipse P400 Midi Tower Case - Gun Metal Window= £47.99 1 x Toshiba P300 1TB 7200RPM 64MB Cache High Performance Hard Drive (HDWD110UZSVA)= £37.99 1 x Gigabyte X99-SLI - Intel Core i7 5820K Six Core CPU & Motherboard Bundle ***£20 Saving***= £495.97 1 x Kingston Fury Black 16GB (4x4GB) DDR4 PC4-19200C15 2400MHz Quad Channel Kit - Black (HX424C15FBK4/16= £59.99 1 x Super Flower Leadex GOLD 550W Fully Modular '80 Plus Gold' Power Supply - Gunmetal= £67.99 1 x MSI GeForce GTX 1070 AERO 8G OC 8192MB GDDR5 PCI-Express Graphics Card= £379.99 1 x Alpenföhn Matterhorn Black CPU Cooler= £39.95 Total: £1,179.86 (includes shipping: £0.00) £55 cashback - https://toptechcashback.com/gb/en/pages/cpumb/qualifying If you need Windows then Windows 10 on USB stick is £89.99. The R9 480 is released end of the month, if you are only using a 1080P monitor it maybe more than adequate. If you want the option of dual GFX cards then pick a 750W PSU.
