I have my cooler working very well and can keep it at around 70 C on full load stress with an I7 930 at 4.2 Ghz
Thing is i need LLC ( Vdroop off) for this to be stable but am not happy with using vdroop off
If for example i can get a higher overclock at reasonable load temps ( sub 75 C)
what is the limit i can run my voltage at 24x 7 and not damage or lessen the life of the CPU. I appreciate that with vdroop the voltage in cpuz is markedly lower than that set in bios so can someone suggest upper limits for the cpuz reading
If i can control my temps how far can i push the voltage bearing in mind this is a workstation that i want to last O/C bragging rights are irrelevant !!
