Mr. Floyd is right. The problem is easily solved, though, by mounting the hard disk in a 5.25" bay with an adapter or an enclosure.
I don't think you'd be able to move the disks far enough forward in the lower drive bay as there's only about 1" between the drives and the fan under normal use. With no drives there you'd have that 120mm fan blowing directly on your GPUs.
