I have started to write up a small general article based on questions I get asked. The point of it will be to post on my own website and at work as general advice.
I do not want it to be too technical.
I would be grateful if you can have a look and comment on it for errors or omissions or suggestions on extra points to add. It is a work in progress but feedback would be helpful!!
It is not always easy to put into words what you know
http://www.ajf1976.pwp.blueyonder.co.uk/photos/cameras.pdf
Andrew
Andrew
