Please review my basket!
22 Jul 2006
I would get a better PSU with a longer warranty, think the Aerocool only has 2 years.
Maybe get a 9060 XT and that will allow you to get a better PSU and motherboard.
A bit over your £1000 budget, but £5 cheaper than your list.
My basket at OcUK:
Total: £1,037.88 (includes delivery: £11.98)​
EDIT​
Price of the 9060 XT is dropping to £300 later today and may be some other stuff, so keep an eye on the sales. ;)
My basket at OcUK:
EDIT​
Thanks for that…just wondering if the 5060ti is the better card to go for regardless? What do you think?
I could get away with just buying the bits that are at risk of skyrocketing in price such as the SSD, Ram and gpu and hold off a little bit on the other bits?
Don't know much about the new Nvidia cards but looking at a couple of reviews it's a bit more powerful and has DLSS, It's up to you though if you think it is worth £80 more than a 9060 XT.
If you are going to do this then get a 2TB drive as suggested by hornetstinger.
All depends on price. If you don't need nvidia for some reason (e.g. games that strongly prefer it, or CUDA), then a 9060 XT 16GB at £300 and a 5060 Ti at £380, the nvidia card loses. I'm also a lot happier paying £300 (or near) for cards of this performance level than closer to £400.
different motherboard
The Nitro is a good balance between features and price, but it isn't anything special, so I wouldn't be bothered about waiting for it.
That board (MSI B650M Gaming Plus) has a good variety of USB ports, VRM looks fine, but it doesn't declare PCI-E 4.0 graphics (officially B650 is not supposed to have it, unofficially some appear to).
Bigger SSD
Corsair have a bazillion models, which makes it hard to keep track, but I believe that's a QLC model. Rated endurance is 450 TB written for the 2TB capacity which strongly suggests it is. Prices are climbing rapidly on these, which makes comparisons difficult, but Team's G70 Pro is rated for 1480 TB written (in the 2TB capacity), so I'd go with that for the same price.
Corsair's RMe doesn't have the best reputation of late, have been issues with DOAs/early failures and QA reported.
Thanks, any other particular board for the money??
Maybe the sapphire pulse?
I like the Pulse, but it doesn't declare PCI-E 5.0 graphics either and the USB ports look lower spec than the Gaming Plus you were looking at. Also no Type-C on the rear I/O, if you care about that.
What would you suggest that is in stock?
If you don't care about PCI-E 5.0 graphics, then the one you suggested is fine, the B650M Gaming Plus (or the B850M Pulse, albeit with less USB 3.x ports).
B850M DS3H has PCI-E 5.0 graphics, but note the limited USB (and other connectivity) on the rear and no WIFI/BT.
Personally, I would decide based on how tight your budget is. If the budget needs to be kept under strict control then I'd just get the Sapphire B650-E in your original spec for £100, since that leaves you a few tenners that could be put to good use on the PSU and SSD (or a 5060 Ti, if you go the nvidia way).
But, if the budget is not that tight, OR you plan on keeping this a long while with CPU+GPU upgrades in mind, I'd only get a board with confirmed PCI-E 5.0 graphics and a decent VRM (e.g. the next X3D, 10800X3D is expected to have 12 cores).
Snag is, there's really nothing I can see that would be suitable in stock at OCUK. The Nitro was the best option :mad:
The B850 of the board you suggested (B850M Gaming Plus) ticks most of the boxes, but that's white, which I assume you don't want?
I think just to get into gaming again I’m going to go with original mobo.
Going to pull plug on this:
My basket at OcUK:
Total: £1,017.84 (includes delivery: £11.98)​
That's a well refined build but I'd not touch the RMe, they've had a history of failures since Corsair changed OEM a little over a year back. That and spending £80 on a 650W budget (gold) PSU is ridiculous, Corsair need their heads tested.
I'd trust either of the following more:
My basket at OcUK:
Total: £155.98 (includes delivery: £7.99)​
Either save and deal with non-modular, or spend more for a better modular PSU with more upgrade potential due to power output.
My basket at OcUK:
Thnaks
What about this PSU? https://www.overclockers.co.uk/aero...plus-gold-modular-power-supply-ca-23s-ae.html
£55 (incl. VAT)
£48 (incl. VAT)
£80 (incl. VAT)
£73 (incl. VAT)
FREE DELIVERY
