- 1 Oct 2010
Ok here we go. I'm working on my parents system which one SOME CDs (not all) introduces a layer of static over the music when being played. Annoyingly if you import the CD (through either iTunes or WMP) this layer of static comes in too. I have tried playing and importing the CD on my system and it's fine
In trying to solve this I have:
Completely rebuilt the PC, was Vista, now Windows 7 (both x64)
Removed the PCI wireless card and the graphics card (so went back to using on board for both)
Disabed on board sound card, imported CD, copied MP3 files to another computer - static remained!
Used a different optical drive (used an external USB CD drive just to make sure there was nothing funny going on down the SATA chain)
Used a different HDD
Unplugged pretty much everything I could from the motherboard that wasn't essential (front USB ports, etc)
Tried each of the sticks of RAM independently
Flashed BIOS to the latest version
I'm pretty much out of ideas. I can only think it's some codec or something that windows installs at build that's causing the issue. Anyone else got any ideas?
The motherboard is an Asus M2N68-VM and it's running and AMD Phenom 9950 Quad processor.
I don't have a spare soundcard lying around, but not sure this would even help! Windows system sounds play fine, if I import the songs on my laptop and then copy files over they play fine on machine, it's just something weird with the import
