- 26 Apr 2004
- Milton Keynes
Hi guys, as above, I'm looking to build a HTPC (microatx mobo). Ideally I'd like to spend as little as possible, SFF would be nice but it's not a requirement, and in fact may be made impossible by the other requirements.
I did look at the Antec Microfusion...it can be had for around £60 so doesn't break the bank, and comes with a remote and PSU, and is reputedly very quiet with the fans set to low/medium, but it requiring a low profile cooler and GPU were a killer for me. I also considered the OcUK Pheonix but the PSU apparently obstructs airflow and it's a tight fit so anything above a low profile CPU cooler is out.
Unfortunately, low profile leaves me quite restricted in terms of which cards I can put in and cooling, which is why I'm bypassing that.
I was planning it around the following spec:
AMD X2 5200+ AM2
Artic Cooling 64 Freezer Pro [I could replace this, but as I have it, it would be a shame not to use it, especially as I know when the fan is on low its very quiet. I'm considering buying a Zalman budget allowing but thats not a guaranteed point]
2GB DDR2
2.5" Laptop 5400RPM SATA
Probably a GT220 [the air-cooled low profile models by all accounts are too loud, and I've had no luck finding a passive model in the UK that isn't full height].
Requirements:
Quiet (sturdy to reduce vibration would help)
Preferably comes with a [quiet] PSU.
Under £100
Will accept full height GPUs
Provides at least 6" clearance from the mobo for the cooler (the artic freezer pro isn't that small)
Any opinions and ideas welcome.
PS. I'm considering the OcUK Aphrodite as it looks like it *should* offer the clearance I'm after, and as it's labelled as a HTPC case you'd think the PSU packaged with it will be relatively quiet! It's not like the spec I'm going for should push even a poor PSU (although I could replace this as need be, it would cut into budget again which Im trying to keep to a minimal level)
AMD X2 5200+ AM2
2GB DDR2
Requirements:
Under £100
