Please Spec Me a GPU,CPU,Motherboard and a PSU?
5 Aug 2006
England
hi
I have a monitor, hdd, 16gb ddr3 Memory, keyboard,mouse and OS and dvd writer.
so all i need is a Radeon GPU/CPU/Motherboard and a PSU on budget of £350 but looking to play GTA5 and maybe just cause 3, really hope this is possible so massive thanks for help or advice.
This is the Tower i have
Cooler Master K-Series K380 USB3.0 Side Window Case for ATX PC
My basket at Overclockers UK:
Total: £388.06
(includes shipping: £11.10)
Thats £376 with free delivery.
The board only has two RAM slots, if your RAM is 4x4Gb then your only using 8GB.
thanks very much for that, so i could just get 2x8gb later then, so would be ok as it sounds like a good setup which i should be able to order friday :)
thanks
curious! if i had an extra £50 what other Motherboard would you of said?
Surely an extra £50 would get you an i5 4690K and a 4GB R9380 instead?
Or just over £50 actually.
thanks
Total: £448.66
(includes shipping: £11.70)
you guys are great thanks, also i still have a spare Raijintek Themis Direct Contact CPU Cooler, would that fit okay on this setup ?
cheers
1 x Gigabyte Z97X-SLI - Devils Canyon Core i5 4690K Bundle **£12 Saving**= £257.98
1 x SuperFlower FX 550W '80 Plus Bronze' Power Supply - Black= £49.99
1 x Sapphire Radeon R9 380 Dual-X 2048MB GDDR5 PCI-Express Graphics Card (11242-02-20G)= £128.99
so this is what im going for which sounds pretty good so im hoping to get it very early this work as im a little down on cash at the moment due to recent things but im fine with that.
thanks again for your help
this is more or less the upgrade path I went with from my 8350.
I also reused my 16gb ram and ssd and hardrive and bluray drive.
just bought the same bundle and then bought a 970 im not disappointed..
get a good cooler on there and youll be able to get a wee overclock going on.
