Hi,
I would really appreciate any help.
I have 3 290s (these to be precise: http://www.overclockers.co.uk/showproduct.php?prodid=GX-015-VX).
They are in an obsidian 800d case with an i7 920, all running at stock. At the moment, on load the graphics cards are getting to around 85 degrees on air, they never go higher but it makes an awful lot of noise. They are being used 24/7 and i'd like to keep them cool and stable, I am not too fussed about overclocking, just keeping the noise and temps down mainly.
Currently I also have a Corsair h50, I would be happy keeping this and just water cooling the 290s if it's much cheaper, but if not then I can remove that and replace it.
I was looking at one of the kits, but it then said I needed extra fittings and GPU blocks which I found, but then I saw something about crossfire connectors and got a bit confused. If someone could put together a basket for me which would all work together and in the 800d case for the 3 cards, I'd really really appreciate it.
I am looking for around £500 max, but I totally understand if it needs to be more, it will just mean me waiting a short while.
Thanks,
Thanks,
