I am looking to get a new rig for as cheap as possible. Now I need it to be in and ITX case as I will be moving it from place to place.
My current rig is:
i5 2500k
16GB DDR2 RAM
256GB SSD Drive
ATI HD 6850 1GB
3TB Back Up Drive
Fractal Design Midi Case
DVD-RW
Now I've had this set up for a long time now. I mainly use it to do 3D modelling work in my spare time as a hobby (I know Quadro & FriPro cards are ideal for 3D work) but all I'm looking for is a spec which matches or beats my current spec that I can fit into an ITX case.
Budget wise I dont know how much it would cost so lets say between £400-£700.
i figured I can used the SSD from my current rig.
Any advice or specs would be greatly appreciated.
My current rig is:
i5 2500k
16GB DDR2 RAM
256GB SSD Drive
ATI HD 6850 1GB
3TB Back Up Drive
DVD-RW
