Please suggest a wide case
The widest is probably the Corsair Air 540. However the Phanteks Enthoo Pro will fit the bill nicely. What are the rest of your specs?
Thanks for the suggestions, I quite like the look of this one: Corsair Carbide Series Air 240 High Airflow PC Case - Black (CC-9011070-WW) what do you reckon?
Other specs are:
AMD A10-5800K Black Edition 3.80GHz (Socket FM2) APU Trinity Quad Core Processor
ASRock FM2A75M-DGS AMD A75 Chipset (Socket FM2) DDR3 Micro ATX Motherboard
Seagate Barracuda 500GB 7200RPM SATA 6Gb/s 16MB Cache - OEM (ST500DM002) HDD
OCZ CoreXtreme 500w '80 Plus' Power Supply
Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual CHannel Kit (PV38G213C1K)
Zalman T1 Mini Tower Case - Black
Samsung SH-224DB/BEBE 24x DVD±RW SATA ReWriter (Black) - OEM
Both the Lian Li PC-7HX (£84.95 t0 £89.99) and the In-Win 703 (£44.99 on TWO) support coolers up to 170mm (2mm to spare!), the Phanteks Enthoo Pro (£79.99 to £89.99) up to 193mm and the In-Win 707 up to 206mm (£79.99 on TWO). There are probably more to choose from, you just need to pick which one you like the look of and what features you want.
