Plex server build help
20 Nov 2010
Hi all!
Been out of the game for a while now.
Was hoping i could some help with choosing parts to build a plex server. I'm not too worried about transcoding as i'll be trying to get everything to directplay to my devices. But, if i can get a cpu that can do a good job at transcoding, that's cool too.
At most i'll be streaming to 2 devices at the same time in 1080p at the very least, going up to 4k.
i'll be streaming videos and will not be storing photos on the server.
I think 16gb of RAM should be sufficient? Is that overkill or underkill? Open to suggestions. and a minimum of 4TB storage. Don't worry about RAID/backups etc.
I would love a small case(mini atx? those cute little cubes lol) if possible, as long as it can support multiple disks and has multiple m2 slots(so i can expand in the future). however if the price of those is significantly more expensive than a regular ATX case, i'd be fine with ATX.
if you want a cpu to aid with a transcode, look for something from Intel with Quick Sync.
look for something like a second hand 9600K and it will beast everything you throw at it.
