Plex streaming PC to TV
24 Jul 2008
Good morning people.
I have a burning question something ive trawled the internet for and having no luck this issue has been here for a year or two and still no success have found other ways to stream but no i want plex back.
I have been happy using plex to stream to my hisence TV from around 2016-19 but it stopped last year and i cannot get it back running.
I just cannot get it to add folders i want to stream ive updated the apps both media player and server and the options are just not there for me now has it been disabled?
PC is just full of media for my little girl and want access to it please.
Lx97fjH
Have you created new libraries for the new folders, or added the folders to existing libraries?
If I access my plex server using a web browser, on the left hand side which lists the libraries, at the bottom there is a 'more >' button.
Clicking this brings up another side menu where I can pin libraries, or edit them.
There is also a '+' next to my server name which will add new libraries, selecting the content type etc.
Its a common issue. I had the exact same with my Panasonic i use in my bedroom. It appears as if the latest version of the server requires a new version of the security for the app that isnt available for the OS on the TV and Panasonic are not interested in updating a firmware on a 4-5 year old tv so you will probably not be able to get it to work unless some clever bod had managed to make a firmware and get it onto the TV.
I just bought a £25 Amazon Firestick (Latest one with the HDMI CEC control) and it works better than the built in app ever did. Better wifi signal so less quality downgrade if the signal is low and the interface is nice and swift.
I think there is a way to get it working by the built in media player and DNLA but it doesnt get all the artwork etc..
Here is a thread on the plex forums about it. Panasonic TV app suddenly claiming server is offline - Plex Players / Smart TVs - Plex Forum I am pretty sure someone in there specifically mentioned hisense as well.
Hope that helps.
yes - you can revert to an older version of the server - I did this on a PC where older channel apps were no longer working with a server update I had manually made
- downloads directory still had the original.
You can use a dnla server from a different provider too, as well as artwork, you can loose rewind/other functionality.
Hope that helps.
I have just purchased a 4k fire stick as my hisence interface is getting slow its helped a lot what did you use software wise for the firestick to stream from my PC.
its actually computer side im struggling with guys the "plex media server" my option to add my own folders for streaming are just not there. or when it does appear "+ You media" it tells me to download the latest version of plex media server which i have done countless times.
ive trawled google for advice all night really am stuggling here,
ive deleted the registry as it was mention elsewhere.
New install, different logins/users too.
Can anybody recommend anything similar to plex? streaming media from my PC to firestick please?
Thats really odd.. in all the years i have been using plex i have never seen that error. I think it has to be a corrupt registry entry or some corruption caused by a update to the server.
did you enable these ? the log may show something
Enable Plex Media Server debug logging
Enable Plex Media Server verbose logging
"type": "info",
"host": "127.0.0.1:32400",
"userAgent": "Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/86.0.4240.198 Safari/537.36",
"browser": {
"platformVersion": "10",
"id": "chrome",
"name": "Chrome",
"version": "86.0",
"webkit": true,
"platform": "Windows",
"platformID": "windows",
"platformModifierKey": "ctrl"
"version": "4.43.4",
"username": "[email protected]",
"cloudUrl": [
"scheme": "https",
"address": "plex.tv",
"uri": "https://plex.tv",
"testState": "connected",
"isBundled": false,
"isFallback": false,
"relay": false,
"isUntested": false,
"isPending": false,
"isConnected": true,
"isUnauthorized": false,
"isUnavailable": false,
"isFailed": false,
"isAborted": false,
"isLoopback": false,
"isPrivate": false,
"isHttps": true,
"isSecure": true,
"isPlexDirect": false,
"currentTest": null,
"sources": [
"id": "internal"
"type": "log:message",
"level": 4,
"message": "[UserManager] autoLogin false",
"time": "2020-11-24T18:11:38.467Z"
"level": 4,
"message": "[Sources] Initializing...",
"time": "2020-11-24T18:11:38.545Z"
"level": 4,
"message": "[Sources] Finished initialization",
"time": "2020-11-24T18:11:38.546Z"
"level": 4,
"message": "[Servers] Initializing...",
"level": 4,
"message": "[Servers] Initialize server without token, [Bundled], http://127.0.0.1:32400",
"time": "2020-11-24T18:11:38.565Z"
"level": 4,
"message": "[Servers] Initialize server without token, [Loopback], http://127.0.0.1:32400",
"time": "2020-11-24T18:11:38.574Z"
"level": 4,
"message": "[Servers] Waiting for initial servers = [Bundled], [Loopback], plex.tv",
"time": "2020-11-24T18:11:38.575Z"
"level": 4,
"message": "[Primary Server] Waiting to set the primary server",
"time": "2020-11-24T18:11:38.584Z"
"level": 4,
"message": "[Primary Server] Waiting for any owned server to connect",
"time": "2020-11-24T18:11:38.585Z"
"level": 4,
"message": "[Commands] Executing testServerConnection",
"time": "2020-11-24T18:11:38.586Z"
"level": 4,
"time": "2020-11-24T18:11:38.587Z"
"level": 4,
"level": 1,
"message": "[Companion] No companion found",
"time": "2020-11-24T18:11:38.588Z"
"level": 4,
"message": "[Servers] Finished initialization",
"type": "navigation",
"route": "dashboard",
"args": [
null
"fragment": "",
"time": "2020-11-24T18:11:38.602Z"
"type": "ajax",
"url": "/web/translations/en.json",
"status": 200,
"responseLength": 2,
"time": "2020-11-24T18:11:38.603Z"
"level": 4,
"message": "[Connections] Testing connection for [Bundled] at http://127.0.0.1:32400/media/providers",
"time": "2020-11-24T18:11:38.639Z"
"level": 4,
"message": "[Connections] Testing legacy connection for [Bundled] at http://127.0.0.1:32400",
"time": "2020-11-24T18:11:38.640Z"
"level": 4,
"message": "[Connections] Testing connection for [Loopback] at http://127.0.0.1:32400/media/providers",
"time": "2020-11-24T18:11:38.648Z"
"level": 4,
"message": "[Connections] Testing legacy connection for [Loopback] at http://127.0.0.1:32400",
"level": 4,
"message": "[Connections] Testing connection for plex.tv at https://plex.tv/monitoring/health",
"time": "2020-11-24T18:11:38.658Z"
"type": "ajax",
"url": "http://127.0.0.1:32400/media/providers?X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Language=en",
"status": 401,
"headers": {
"Accept-Language": "en",
"Accept": "application/json"
"statusText": "Unauthorized",
"response": "<html><head><title>Unauthorized</title></head><body><h1>401 Unauthorized</h1></body></html>",
"time": "2020-11-24T18:11:38.671Z"
"level": 1,
"message": "[Connections] [Bundled] is unauthorized at http://127.0.0.1:32400/media/providers (Status 401)",
"time": "2020-11-24T18:11:38.674Z"
"level": 1,
"time": "2020-11-24T18:11:38.675Z"
"level": 4,
"message": "[Commands] Executing populateServerIdentity",
"time": "2020-11-24T18:11:38.678Z"
"level": 4,
"message": "[Identity] Requesting the machine identifier of [Bundled] at http://127.0.0.1:32400/identity",
"time": "2020-11-24T18:11:38.679Z"
"type": "ajax",
"url": "http://127.0.0.1:32400?X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Language=en",
"status": 401,
"headers": {
"response": "<html><head><script>window.location = window.location.href.match(/(^.+\\/)[^\\/]*$/)[1] + 'web/index.html';</script><title>Unauthorized</title></head><body><h1>401 Unauthorized</h1></body></html>",
"time": "2020-11-24T18:11:38.681Z"
"type": "ajax",
"status": 401,
"headers": {
"time": "2020-11-24T18:11:38.683Z"
"level": 1,
"message": "[Connections] [Loopback] is unauthorized at http://127.0.0.1:32400/media/providers (Status 401)",
"time": "2020-11-24T18:11:38.684Z"
"level": 1,
"level": 4,
"time": "2020-11-24T18:11:38.692Z"
"level": 4,
"message": "[Identity] Requesting the machine identifier of [Loopback] at http://127.0.0.1:32400/identity",
"type": "ajax",
"status": 401,
"headers": {
"time": "2020-11-24T18:11:38.694Z"
"level": 4,
"message": "[Identity] Machine identifier found for [Bundled]: fac29578f2c150d8a700543ee87e4028eebece02",
"time": "2020-11-24T18:11:38.699Z"
"type": "ajax",
"url": "http://127.0.0.1:32400/identity?X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Language=en",
"status": 200,
"headers": {
"responseLength": 188,
"time": "2020-11-24T18:11:38.702Z"
"level": 4,
"message": "[Identity] Machine identifier found for [Loopback]: fac29578f2c150d8a700543ee87e4028eebece02",
"time": "2020-11-24T18:11:38.706Z"
"type": "ajax",
"status": 200,
"headers": {
"level": 4,
"message": "[Connections] plex.tv connected at https://plex.tv/monitoring/health",
"time": "2020-11-24T18:11:38.714Z"
"level": 2,
"message": "[Connections] Active connection to plex.tv is https://plex.tv",
"time": "2020-11-24T18:11:38.718Z"
"level": 1,
"time": "2020-11-24T18:11:38.720Z"
"level": 4,
"message": "[User] Token promise succeeded, accessToken=REDACTED",
"type": "ajax",
"url": "https://plex.tv/monitoring/health?X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Language=en",
"status": 200,
"headers": {
"responseLength": 0,
"time": "2020-11-24T18:11:38.727Z"
"level": 3,
"message": "[Vote:mwz89u0v9bet59d0wyaxqj5f] Elected",
"time": "2020-11-24T18:11:38.856Z"
"level": 2,
"message": "[Companion] Elected to poll leader role",
"level": 4,
"message": "[User] userPromise succeeded",
"time": "2020-11-24T18:11:38.880Z"
"type": "ajax",
"url": "https://plex.tv/api/v2/user?includeSubscriptions=1&includeProviders=1&includeSettings=1&includeSharedSettings=1&X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Language=en&X-Plex-Token=TOKEN",
"status": 200,
"headers": {
"responseLength": 16958,
"time": "2020-11-24T18:11:38.882Z"
"level": 4,
"message": "[Servers] Finding resources through plex.tv",
"time": "2020-11-24T18:11:38.988Z"
"level": 4,
"message": "[Servers] Waiting for initial servers = [Bundled], [Loopback]",
"time": "2020-11-24T18:11:38.993Z"
"level": 4,
"message": "[CloudServerEventManager] Opening server event connection to plex.tv at wss://pubsub.plex.tv/sub/websockets/12952834/j0iag2cctn5wiifp1qrhwaln?X-Plex-Token=REDACTED",
"time": "2020-11-24T18:11:38.998Z"
"level": 2,
"message": "[Companion] Registering player with plex.tv, clientID=\"j0iag2cctn5wiifp1qrhwaln\"",
"time": "2020-11-24T18:11:38.999Z"
"type": "ajax",
"url": "https://plex.tv/api/v2/home?X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Language=en&X-Plex-Token=TOKEN",
"status": 200,
"headers": {
"responseLength": 147,
"time": "2020-11-24T18:11:39.017Z"
"level": 3,
"message": "[Metrics] Updating session last interaction time",
"time": "2020-11-24T18:11:39.062Z"
"type": "ajax",
"url": "https://plex.tv/api/v2/user/privacy?X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Token=TOKEN&X-Plex-Language=en",
"status": 200,
"headers": {
"responseLength": 6415,
"time": "2020-11-24T18:11:39.063Z"
"type": "ajax",
"url": "https://analytics.plex.tv/collect/event",
"status": 0,
"params": "{\"deviceIdentifier\":\"j0iag2cctn5wiifp1qrhwaln\",\"context\":{\"campaign\":{},\"device\":{\"product\":\"Plex Web\",\"version\":\"4.43.4\",\"platform\":\"Chrome\",\"platformVersion\":\"86.0\",\"device\":\"Windows\",\"model\":\"bundled\",\"screenResolution\":\"2048x1010,2048x1152\",\"layout\":\"desktop\",\"protocol\":\"http-loopback\"},\"user\":{\"anonymous\":false}},\"userId\":12952834,\"event\":\"client:shutdown\",\"interaction\":false,\"properties\":{\"sessionLength\":80,\"playbackCount\":0,\"playbackTime\":0},\"sessionIdentifier\":\"2c2df4ec-6746-4f94-8b4d-fb47c8f6531c\"}",
"statusText": "error",
"time": "2020-11-24T18:11:39.064Z"
"type": "ajax",
"status": 0,
"params": "{\"deviceIdentifier\":\"j0iag2cctn5wiifp1qrhwaln\",\"context\":{\"campaign\":{},\"device\":{\"product\":\"Plex Web\",\"version\":\"4.43.4\",\"platform\":\"Chrome\",\"platformVersion\":\"86.0\",\"device\":\"Windows\",\"model\":\"bundled\",\"screenResolution\":\"2048x1010,2048x1152\",\"layout\":\"desktop\",\"protocol\":\"http-loopback\"},\"user\":{\"anonymous\":false}},\"userId\":12952834,\"event\":\"client:start\",\"interaction\":true,\"properties\":{\"mode\":\"uno\",\"latency\":955},\"sessionIdentifier\":\"7a293d75-1e04-4e15-8d33-0625ce27d742\"}",
"time": "2020-11-24T18:11:39.066Z"
"level": 4,
"time": "2020-11-24T18:11:39.137Z"
"level": 4,
"message": "[Servers] Found 2 resources through plex.tv",
"time": "2020-11-24T18:11:39.138Z"
"level": 4,
"time": "2020-11-24T18:11:39.139Z"
"level": 1,
"message": "[Connections] All connections to [Bundled] failed",
"time": "2020-11-24T18:11:39.142Z"
"level": 4,
"message": "[Servers] Waiting for initial servers = [Loopback]",
"time": "2020-11-24T18:11:39.143Z"
"level": 1,
"message": "[Identity] [Loopback] and [Bundled] (cached) collide",
"time": "2020-11-24T18:11:39.151Z"
"level": 4,
"message": "[Identity] Merging [Loopback] into [Bundled] (cached)",
"level": 1,
"message": "[Servers] [Loopback] was removed",
"time": "2020-11-24T18:11:39.153Z"
"level": 4,
"message": "[Connections] Aborting all pending connection tests for [Loopback]",
"time": "2020-11-24T18:11:39.154Z"
"level": 4,
"message": "[Commands] Executing abortServerConnectionTest",
"level": 4,
"message": "[Servers] Found all servers = plex.tv",
"level": 4,
"message": "[Primary Server] Waiting for any eligible server to connect",
"time": "2020-11-24T18:11:39.155Z"
"level": 4,
"message": "[Primary Server] Waiting for any eligible server",
"level": 4,
"time": "2020-11-24T18:11:39.156Z"
"level": 4,
"level": 4,
"time": "2020-11-24T18:11:39.157Z"
"level": 1,
"message": "[Connections] All connections to [Loopback] failed",
"type": "ajax",
"url": "https://plex.tv/api/v2/resources?includeHttps=1&includeRelay=1&X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Token=TOKEN&X-Plex-Language=en",
"status": 200,
"headers": {
"responseLength": 1349,
"time": "2020-11-24T18:11:39.161Z"
"type": "ajax",
"url": "https://plex.tv/api/claim/subscribe?X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Token=TOKEN&X-Plex-Language=en",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:39.206Z"
"type": "ajax",
"url": "https://plex.tv/api/v2/companions?X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Token=TOKEN&X-Plex-Language=en",
"status": 200,
"headers": {
"responseLength": 179,
"time": "2020-11-24T18:11:39.252Z"
"type": "ajax",
"url": "https://plex.tv/api/home/users?X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Token=TOKEN&X-Plex-Language=en",
"status": 200,
"headers": {
"responseLength": 794,
"time": "2020-11-24T18:11:39.255Z"
"type": "ajax",
"url": "https://plex.tv/devices.xml?X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Token=TOKEN&X-Plex-Language=en",
"status": 200,
"headers": {
"Accept": "application/xml"
"responseLength": 3259,
"time": "2020-11-24T18:11:39.290Z"
"type": "ajax",
"url": "https://plex.tv/pms/social/networks?X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Token=TOKEN&X-Plex-Language=en",
"status": 200,
"headers": {
"responseLength": 352,
"time": "2020-11-24T18:11:39.315Z"
"type": "ajax",
"url": "https://plex.tv/api/invites/requests?X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Token=TOKEN&X-Plex-Language=en",
"status": 200,
"headers": {
"responseLength": 206,
"time": "2020-11-24T18:11:39.334Z"
"type": "ajax",
"url": "https://plex.tv/api/users?X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Token=TOKEN&X-Plex-Language=en",
"status": 200,
"headers": {
"responseLength": 1118,
"time": "2020-11-24T18:11:39.408Z"
"type": "ajax",
"url": "https://plex.tv/api/announcements?X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Token=TOKEN&X-Plex-Language=en",
"status": 200,
"headers": {
"responseLength": 3443,
"time": "2020-11-24T18:11:39.411Z"
"type": "ajax",
"url": "https://plex.tv/api/v2/home?X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Token=TOKEN&X-Plex-Language=en",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:39.469Z"
"type": "ajax",
"url": "https://plex.tv/media/providers?X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Token=TOKEN&X-Plex-Language=en",
"status": 200,
"headers": {
"responseLength": 1521,
"time": "2020-11-24T18:11:39.533Z"
"type": "ajax",
"url": "https://vod.provider.plex.tv",
"status": 200,
"headers": {
"X-Plex-Product": "Plex Web",
"X-Plex-Version": "4.43.4",
"X-Plex-Client-Identifier": "j0iag2cctn5wiifp1qrhwaln",
"X-Plex-Platform": "Chrome",
"X-Plex-Platform-Version": "86.0",
"X-Plex-Sync-Version": 2,
"X-Plex-Features": "external-media,indirect-media",
"X-Plex-Model": "bundled",
"X-Plex-Device": "Windows",
"X-Plex-Device-Screen-Resolution": "2048x1010,2048x1152",
"X-Plex-Token": "TOKEN",
"X-Plex-Language": "en",
"X-Plex-Drm": "widevine",
"X-Plex-Text-Format": "plain",
"X-Plex-Provider-Version": "1.3",
"responseLength": 1440,
"time": "2020-11-24T18:11:39.549Z"
"type": "ajax",
"url": "https://music.provider.plex.tv",
"status": 200,
"headers": {
"responseLength": 1622,
"time": "2020-11-24T18:11:39.563Z"
"type": "ajax",
"url": "https://metadata.provider.plex.tv",
"status": 200,
"headers": {
"responseLength": 634,
"time": "2020-11-24T18:11:39.568Z"
"type": "ajax",
"url": "https://epg.provider.plex.tv",
"status": 200,
"headers": {
"responseLength": 927,
"time": "2020-11-24T18:11:39.574Z"
"type": "ajax",
"url": "https://webshows.provider.plex.tv",
"status": 200,
"headers": {
"X-Plex-Text-Format": "html",
"responseLength": 1475,
"time": "2020-11-24T18:11:39.582Z"
"type": "ajax",
"url": "https://news.provider.plex.tv",
"status": 200,
"headers": {
"responseLength": 1843,
"time": "2020-11-24T18:11:39.593Z"
"type": "ajax",
"url": "https://podcasts.provider.plex.tv",
"status": 200,
"headers": {
"responseLength": 1635,
"time": "2020-11-24T18:11:39.601Z"
"level": 4,
"message": "[MediaElement] Creating new media element. type: audio",
"time": "2020-11-24T18:11:40.074Z"
"level": 4,
"message": "[MediaElement] Releasing media element to pool. type: audio",
"time": "2020-11-24T18:11:40.121Z"
"level": 4,
"message": "[Commands] Executing switchUser",
"time": "2020-11-24T18:11:40.155Z"
"level": 4,
"message": "[Commands] Executing authenticateWithServer",
"level": 2,
"message": "[CloudServerEventManager] Opened server event connection to plex.tv at wss://pubsub.plex.tv/sub/websockets/12952834/j0iag2cctn5wiifp1qrhwaln?X-Plex-Token=REDACTED",
"time": "2020-11-24T18:11:40.266Z"
"level": 4,
"message": "[Commands] Executing resetUser",
"time": "2020-11-24T18:11:40.447Z"
"level": 1,
"message": "[Servers] Failed to request resources through plex.tv",
"time": "2020-11-24T18:11:40.466Z"
"args": [
null
"fragment": "",
"time": "2020-11-24T18:11:40.477Z"
"level": 4,
"level": 4,
"message": "[CloudServerEventManager] Closing server event connection to plex.tv at wss://pubsub.plex.tv/sub/websockets/12952834/j0iag2cctn5wiifp1qrhwaln?X-Plex-Token=REDACTED",
"time": "2020-11-24T18:11:40.480Z"
"args": [
null
"fragment": "",
"time": "2020-11-24T18:11:40.483Z"
"level": 4,
"message": "[Servers] Clearing...",
"time": "2020-11-24T18:11:40.491Z"
"level": 3,
"message": "[Workers] Mock worker sending message {\n \"type\": \"SIGN_OUT\"\n}",
"time": "2020-11-24T18:11:40.503Z"
"type": "ajax",
"url": "https://plex.tv/api/v2/home/users/0e6ccde12476604f/switch?includeSubscriptions=1&includeProviders=1&includeSettings=1&includeSharedSettings=1&X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Token=TOKEN&X-Plex-Language=en",
"status": 201,
"headers": {
"statusText": "Created",
"response": "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n<user id=\"12952834\" uuid=\"0e6ccde12476604f\" username=\"[email protected]\" title=\"[email protected]\" email=\"EMAIL\">\n <providers>\n </providers>\n <subscription active=\"0\" subscribedAt=\"\" status=\"Inactive\" paymentService=\"\" plan=\"\">\n <features>\n <feature id=\"camera_upload\"/>\n <feature id=\"home\"/>\n <feature id=\"adaptive_bitrate\"/>\n <feature id=\"photos-metadata-edition\"/>\n <feature id=\"collections\"/>\n <feature id=\"radio\"/>\n <feature id=\"tuner-sharing\"/>\n <feature id=\"photos-favorites\"/>\n <feature id=\"mediaproviders-news-platform-specific\"/>\n <feature id=\"federated-auth\"/>\n <feature id=\"livetv\"/>\n <feature id=\"Android - PiP\"/>\n <feature id=\"news\"/>\n <feature id=\"podcasts\"/>\n <feature id=\"livetv-platform-specific\"/>\n <feature id=\"webshows\"/>\n <feature id=\"type-first\"/>\n <feature id=\"unsupportedtuners\"/>\n <feature id=\"kevin-bacon\"/>\n <feature id=\"live-tv-channels-grid\"/>\n <feature id=\"Subtitles on Demand\"/>\n <feature id=\"web-log-viewer\"/>\n <feature id=\"client-radio-stations\"/>\n <feature id=\"music\"/>\n <feature id=\"TREBLE-show-features\"/>\n <feature id=\"web_server_dashboard\"/>\n <feature id=\"chromecast-music-mp\"/>\n <feature id=\"conan_redirect_qa\"/>\n <feature id=\"conan_redirect_alpha\"/>\n <feature id=\"conan_redirect_beta\"/>\n <feature id=\"conan_redirect_public\"/>\n <feature id=\"news_local_now\"/>\n <feature id=\"transcoder_cache\"/>\n <feature id=\"live-tv-support-incomplete-segments\"/>\n <feature id=\"companions_sonos\"/>\n <feature id=\"users-and-sharing\"/>\n <feature id=\"web-share-v2\"/>\n <feature id=\"sonos-client-feature\"/>\n <feature id=\"artist-tv\"/>\n <feature id=\"music_preview\"/>\n <feature id=\"cloud-livetv\"/>\n <feature id=\"singleitemsharing\"/>\n <feature id=\"exclude restrictions\"/>\n <feature id=\"vod\"/>\n <feature id=\"signin_with_apple\"/>\n <feature id=\"drm_support\"/>\n <feature id=\"metadata\"/>\n <feature id=\"tunefind-clients\"/>\n <feature id=\"Android - Dolby Vision\"/>\n <feature id=\"parental-controls\"/>\n <feature id=\"spring_serve_ad_provider\"/>\n <feature id=\"conan_redirect_nightlies\"/>\n <feature id=\"conan_redirect_nightly\"/>\n <feature id=\"vod_subtitles\"/>\n <feature id=\"watchlist\"/>\n <feature id=\"create_anonymous_users\"/>\n <feature id=\"web-desktop-v4-home\"/>\n <feature id=\"web-desktop-v4-pre-plays\"/>\n <feature id=\"client-non-destructive-comskip\"/>\n <feature id=\"web-desktop-live-tv-chromecast-remote-player\"/>\n <feature id=\"watch-together-invite\"/>\n <feature id=\"spotlight-style-hub\"/>\n <feature id=\"tunefind-vod\"/>\n <feature id=\"live-tv-on-plex-subtitles\"/>\n <feature id=\"ios14-privacy-banner\"/>\n <feature id=\"two-factor-authentication\"/>\n <feature id=\"amazon-loop-debug\"/>\n <feature id=\"vod_cloudflare\"/>\n </features>\n </subscription>\n <profile autoSelectAudio=\"1\" defaultAudioLanguage=\"\" defaultSubtitleLanguage=\"\" autoSelectSubtitle=\"1\" defaultSubtitleAccessibility=\"0\" defaultSubtitleForced=\"0\"/>\n <entitlements>\n </entitlements>\n <settings>\n <setting id=\"experience\" type=\"json\" value=\"{&quot;autoHomeHubsEnabled&quot;:true,&quot;autoPinnedProviders&quot;:[&quot;myPlex--tv.plex.provider.vod&quot;,&quot;myPlex--tv.plex.provider.epg&quot;],&quot;isSidebarCollapsed&quot;:true,&quot;showAdvancedSettings&quot;:true,&quot;schemaVersion&quot;:3,&quot;homeSettings&quot;:{&quot;hasSeededProviderPromotedContent&quot;:true,&quot;settingsKey&quot;:&quot;4tfud2fcocgmi0for2u06paj&quot;,&quot;hubs&quot;:[{&quot;hubIdentifier&quot;:&quot;movies.continueWatching&quot;,&quot;key&quot;:&quot;/hubs/sections/movies/continueWatching&quot;,&quot;style&quot;:&quot;hero&quot;,&quot;title&quot;:&quot;Continue Watching&quot;,&quot;type&quot;:&quot;mixed&quot;,&quot;id&quot;:&quot;myPlex--tv.plex.provider.vod--movies.continueWatching&quot;,&quot;directoryKey&quot;:&quot;/hubs/promoted&quot;,&quot;provider&quot;:{&quot;identifier&quot;:&quot;tv.plex.provider.vod&quot;,&quot;title&quot;:&quot;Movies &amp; Shows&quot;},&quot;server&quot;:{&quot;friendlyName&quot;:&quot;plex.tv&quot;,&quot;machineIdentifier&quot;:&quot;myPlex&quot;}},{&quot;hubIdentifier&quot;:&quot;movies.recommended&quot;,&quot;key&quot;:&quot;/hubs/sections/movies/recommended&quot;,&quot;title&quot;:&quot;Recommended For You&quot;,&quot;type&quot;:&quot;mixed&quot;,&quot;id&quot;:&quot;myPlex--tv.plex.provider.vod--movies.recommended&quot;,&quot;directoryKey&quot;:&quot;/hubs/promoted&quot;,&quot;provider&quot;:{&quot;identifier&quot;:&quot;tv.plex.provider.vod&quot;,&quot;title&quot;:&quot;Movies &amp; Shows&quot;},&quot;server&quot;:{&quot;friendlyName&quot;:&quot;plex.tv&quot;,&quot;machineIdentifier&quot;:&quot;myPlex&quot;}},{&quot;hubIdentifier&quot;:&quot;movies.recentlyAdded&quot;,&quot;key&quot;:&quot;/hubs/sections/movies/recentlyAdded&quot;,&quot;title&quot;:&quot;Recently Added&quot;,&quot;type&quot;:&quot;movie&quot;,&quot;id&quot;:&quot;myPlex--tv.plex.provider.vod--movies.recentlyAdded&quot;,&quot;directoryKey&quot;:&quot;/hubs/promoted&quot;,&quot;provider&quot;:{&quot;identifier&quot;:&quot;tv.plex.provider.vod&quot;,&quot;title&quot;:&quot;Movies &amp; Shows&quot;},&quot;server&quot;:{&quot;friendlyName&quot;:&quot;plex.tv&quot;,&quot;machineIdentifier&quot;:&quot;myPlex&quot;}},{&quot;hubIdentifier&quot;:&quot;movies.popular&quot;,&quot;key&quot;:&quot;/hubs/sections/movies/popular&quot;,&quot;title&quot;:&quot;Most Popular&quot;,&quot;type&quot;:&quot;movie&quot;,&quot;id&quot;:&quot;myPlex--tv.plex.provider.vod--movies.popular&quot;,&quot;directoryKey&quot;:&quot;/hubs/promoted&quot;,&quot;provider&quot;:{&quot;identifier&quot;:&quot;tv.plex.provider.vod&quot;,&quot;title&quot;:&quot;Movies &amp; Shows&quot;},&quot;server&quot;:{&quot;friendlyName&quot;:&quot;plex.tv&quot;,&quot;machineIdentifier&quot;:&quot;myPlex&quot;}},{&quot;hubIdentifier&quot;:&quot;movies.plexpicks&quot;,&quot;key&quot;:&quot;/hubs/sections/movies/plexpicks&quot;,&quot;title&quot;:&quot;Plex Picks&quot;,&quot;type&quot;:&quot;mixed&quot;,&quot;id&quot;:&quot;myPlex--tv.plex.provider.vod--movies.plexpicks&quot;,&quot;directoryKey&quot;:&quot;/hubs/promoted&quot;,&quot;provider&quot;:{&quot;identifier&quot;:&quot;tv.plex.provider.vod&quot;,&quot;title&quot;:&quot;Movies &amp; Shows&quot;},&quot;server&quot;:{&quot;friendlyName&quot;:&quot;plex.tv&quot;,&quot;machineIdentifier&quot;:&quot;myPlex&quot;}},{&quot;hubIdentifier&quot;:&quot;movies.dramatv&quot;,&quot;key&quot;:&quot;/hubs/sections/movies/dramatv&quot;,&quot;title&quot;:&quot;Drama TV&quot;,&quot;type&quot;:&quot;show&quot;,&quot;id&quot;:&quot;myPlex--tv.plex.provider.vod--movies.dramatv&quot;,&quot;directoryKey&quot;:&quot;/hubs/promoted&quot;,&quot;provider&quot;:{&quot;identifier&quot;:&quot;tv.plex.provider.vod&quot;,&quot;title&quot;:&quot;Movies &amp; Shows&quot;},&quot;server&quot;:{&quot;friendlyName&quot;:&quot;plex.tv&quot;,&quot;machineIdentifier&quot;:&quot;myPlex&quot;}},{&quot;hubIdentifier&quot;:&quot;home.featuredChannels&quot;,&quot;key&quot;:&quot;/hubs/sections/home/featuredChannels&quot;,&quot;style&quot;:&quot;shelf&quot;,&quot;title&quot;:&quot;Featured Channels&quot;,&quot;type&quot;:&quot;channels&quot;,&quot;id&quot;:&quot;myPlex--tv.plex.provider.epg--home.featuredChannels&quot;,&quot;directoryKey&quot;:&quot;/hubs/promoted&quot;,&quot;provider&quot;:{&quot;identifier&quot;:&quot;tv.plex.provider.epg&quot;,&quot;title&quot;:&quot;Live TV&quot;},&quot;server&quot;:{&quot;friendlyName&quot;:&quot;plex.tv&quot;,&quot;machineIdentifier&quot;:&quot;myPlex&quot;}},{&quot;hubIdentifier&quot;:&quot;home.onDeck&quot;,&quot;key&quot;:&quot;/hubs/sections/home/onDeck&quot;,&quot;subtype&quot;:&quot;webshow&quot;,&quot;title&quot;:&quot;On Deck&quot;,&quot;type&quot;:&quot;episode&quot;,&quot;id&quot;:&quot;myPlex--tv.plex.provider.webshows--home.onDeck&quot;,&quot;directoryKey&quot;:&quot;/hubs/promoted&quot;,&quot;provider&quot;:{&quot;identifier&quot;:&quot;tv.plex.provider.webshows&quot;,&quot;title&quot;:&quot;Web Shows&quot;},&quot;server&quot;:{&quot;friendlyName&quot;:&quot;plex.tv&quot;,&quot;machineIdentifier&quot;:&quot;myPlex&quot;}},{&quot;hubIdentifier&quot;:&quot;home.filmAndTV&quot;,&quot;key&quot;:&quot;/hubs/sections/home/filmAndTV&quot;,&quot;subtype&quot;:&quot;webshow&quot;,&quot;title&quot;:&quot;Film &amp; TV&quot;,&quot;type&quot;:&quot;episode&quot;,&quot;id&quot;:&quot;myPlex--tv.plex.provider.webshows--home.filmAndTV&quot;,&quot;directoryKey&quot;:&quot;/hubs/promoted&quot;,&quot;provider&quot;:{&quot;identifier&quot;:&quot;tv.plex.provider.webshows&quot;,&quot;title&quot;:&quot;Web Shows&quot;},&quot;server&quot;:{&quot;friendlyName&quot;:&quot;plex.tv&quot;,&quot;machineIdentifier&quot;:&quot;myPlex&quot;}},{&quot;hubIdentifier&quot;:&quot;home.newscast&quot;,&quot;key&quot;:&quot;/hubs/sections/home/newscast&quot;,&quot;subtype&quot;:&quot;news&quot;,&quot;title&quot;:&quot;My Headlines&quot;,&quot;type&quot;:&quot;clip&quot;,&quot;id&quot;:&quot;myPlex--tv.plex.provider.news--home.newscast&quot;,&quot;directoryKey&quot;:&quot;/hubs/promoted&quot;,&quot;provider&quot;:{&quot;identifier&quot;:&quot;tv.plex.provider.news&quot;,&quot;title&quot;:&quot;News&quot;},&quot;server&quot;:{&quot;friendlyName&quot;:&quot;plex.tv&quot;,&quot;machineIdentifier&quot;:&quot;myPlex&quot;}},{&quot;hubIdentifier&quot;:&quot;home.onDeck&quot;,&quot;key&quot;:&quot;/hubs/sections/home/onDeck&quot;,&quot;subtype&quot;:&quot;podcast&quot;,&quot;title&quot;:&quot;On Deck&quot;,&quot;type&quot;:&quot;mixed&quot;,&quot;id&quot;:&quot;myPlex--tv.plex.provider.podcasts--home.onDeck&quot;,&quot;directoryKey&quot;:&quot;/hubs/promoted&quot;,&quot;provider&quot;:{&quot;identifier&quot;:&quot;tv.plex.provider.podcasts&quot;,&quot;title&quot;:&quot;Podcasts&quot;},&quot;server&quot;:{&quot;friendlyName&quot;:&quot;plex.tv&quot;,&quot;machineIdentifier&quot;:&quot;myPlex&quot;}},{&quot;hubIdentifier&quot;:&quot;home.recommended&quot;,&quot;key&quot;:&quot;/hubs/sections/home/recommended&quot;,&quot;subtype&quot;:&quot;podcast&quot;,&quot;title&quot;:&quot;Recommended&quot;,&quot;type&quot;:&quot;show&quot;,&quot;id&quot;:&quot;myPlex--tv.plex.provider.podcasts--home.recommended&quot;,&quot;directoryKey&quot;:&quot;/hubs/promoted&quot;,&quot;provider&quot;:{&quot;identifier&quot;:&quot;tv.plex.provider.podcasts&quot;,&quot;title&quot;:&quot;Podcasts&quot;},&quot;server&quot;:{&quot;friendlyName&quot;:&quot;plex.tv&quot;,&quot;machineIdentifier&quot;:&quot;myPlex&quot;}}]},&quot;sidebarSettings&quot;:{&quot;hasCompletedSetup&quot;:true,&quot;pinnedSources&quot;:[{&quot;key&quot;:&quot;source--movies--myPlex--tv.plex.provider.vod--movies&quot;,&quot;sourceType&quot;:&quot;movies&quot;,&quot;machineIdentifier&quot;:&quot;myPlex&quot;,&quot;providerIdentifier&quot;:&quot;tv.plex.provider.vod&quot;,&quot;directoryID&quot;:&quot;movies&quot;,&quot;directoryIcon&quot;:&quot;https://provider-static.plex.tv/icons/vod-560.svg&quot;,&quot;title&quot;:&quot;Movies &amp; Shows&quot;,&quot;serverFriendlyName&quot;:&quot;plex.tv&quot;,&quot;providerSourceTitle&quot;:&quot;On Plex&quot;,&quot;isCloud&quot;:true,&quot;isFullOwnedServer&quot;:false},{&quot;key&quot;:&quot;source--dvr--myPlex--tv.plex.provider.epg--home&quot;,&quot;sourceType&quot;:&quot;dvr&quot;,&quot;machineIdentifier&quot;:&quot;myPlex&quot;,&quot;providerIdentifier&quot;:&quot;tv.plex.provider.epg&quot;,&quot;directoryID&quot;:&quot;home&quot;,&quot;directoryIcon&quot;:&quot;https://provider-static.plex.tv/icons/epg-560.svg&quot;,&quot;title&quot;:&quot;Live TV&quot;,&quot;serverFriendlyName&quot;:&quot;plex.tv&quot;,&quot;providerSourceTitle&quot;:&quot;On Plex&quot;,&quot;isCloud&quot;:true,&quot;isFullOwnedServer&quot;:false},{&quot;key&quot;:&quot;source--webShows--myPlex--tv.plex.provider.webshows--home&quot;,&quot;sourceType&quot;:&quot;webShows&quot;,&quot;machineIdentifier&quot;:&quot;myPlex&quot;,&quot;providerIdentifier&quot;:&quot;tv.plex.provider.webshows&quot;,&quot;directoryID&quot;:&quot;home&quot;,&quot;directoryIcon&quot;:&quot;https://provider-static.plex.tv/icons/webshows-560.svg&quot;,&quot;title&quot;:&quot;Web Shows&quot;,&quot;serverFriendlyName&quot;:&quot;plex.tv&quot;,&quot;providerSourceTitle&quot;:null,&quot;isCloud&quot;:true,&quot;isFullOwnedServer&quot;:false},{&quot;key&quot;:&quot;source--news--myPlex--tv.plex.provider.news--home&quot;,&quot;sourceType&quot;:&quot;news&quot;,&quot;machineIdentifier&quot;:&quot;myPlex&quot;,&quot;providerIdentifier&quot;:&quot;tv.plex.provider.news&quot;,&quot;directoryID&quot;:&quot;home&quot;,&quot;directoryIcon&quot;:&quot;https://provider-static.plex.tv/icons/news-560.svg&quot;,&quot;title&quot;:&quot;News&quot;,&quot;serverFriendlyName&quot;:&quot;plex.tv&quot;,&quot;providerSourceTitle&quot;:null,&quot;isCloud&quot;:true,&quot;isFullOwnedServer&quot;:false},{&quot;key&quot;:&quot;source--podcasts--myPlex--tv.plex.provider.podcasts--home&quot;,&quot;sourceType&quot;:&quot;podcasts&quot;,&quot;machineIdentifier&quot;:&quot;myPlex&quot;,&quot;providerIdentifier&quot;:&quot;tv.plex.provider.podcasts&quot;,&quot;directoryID&quot;:&quot;home&quot;,&quot;directoryIcon&quot;:&quot;https://provider-static.plex.tv/icons/podcasts-560.svg&quot;,&quot;title&quot;:&quot;Podcasts&quot;,&quot;serverFriendlyName&quot;:&quot;plex.tv&quot;,&quot;providerSourceTitle&quot;:null,&quot;isCloud&quot;:true,&quot;isFullOwnedServer&quot;:false},{&quot;key&quot;:&quot;source--music--myPlex--tv.plex.provider.music--tidal&quot;,&quot;sourceType&quot;:&quot;music&quot;,&quot;machineIdentifier&quot;:&quot;myPlex&quot;,&quot;providerIdentifier&quot;:&quot;tv.plex.provider.music&quot;,&quot;directoryID&quot;:&quot;tidal&quot;,&quot;directoryIcon&quot;:&quot;https://provider-static.plex.tv/icons/music-560.svg&quot;,&quot;title&quot;:&quot;Music&quot;,&quot;serverFriendlyName&quot;:&quot;plex.tv&quot;,&quot;providerSourceTitle&quot;:&quot;On TIDAL&quot;,&quot;isCloud&quot;:true,&quot;isFullOwnedServer&quot;:false}]}}\" hidden=\"1\" updatedAt=\"1606241466\"/>\n </settings>\n <subscriptions>\n </subscriptions>\n <pastSubscriptions>\n </pastSubscriptions>\n <trials>\n </trials>\n <services>\n <service identifier=\"epg\" endpoint=\"https://epg.provider.plex.tv\" token=\"TOKEN\"=\" status=\"online\"/>\n <service identifier=\"epg-staging\" endpoint=\"https://epg-staging.provider.plex.tv\" token=\"TOKEN\"=\" status=\"online\"/>\n <service identifier=\"epg-dev\" endpoint=\"https://epg-dev.provider.plex.tv\" token=\"TOKEN\"=\" status=\"online\"/>\n <service identifier=\"eyeq\" endpoint=\"https://c4412416.ipg.web.cddbp.net/webapi/xml/1.0/\" token=\"TOKEN\"/Hz5nsS9o65Yz77qvh63pYmUN+TaVHeonhsQWlzYGcsik1opEU3toj\" status=\"online\"/>\n <service identifier=\"eyeq-channel-icons\" endpoint=\"http://akamai-b.cdn.cddbp.net/cds/2.0/image\" status=\"online\"/>\n <service identifier=\"metadata\" endpoint=\"https://metadata.provider.plex.tv\" token=\"TOKEN\"=\" status=\"online\"/>\n <service identifier=\"metadata-dev\" endpoint=\"https://metadata-dev.provider.plex.tv\" token=\"TOKEN\"=\" status=\"online\"/>\n <service identifier=\"metadata-provider\" endpoint=\"https://mpm.plex.tv/\" status=\"online\"/>\n <service identifier=\"tmsapi\" endpoint=\"https://tmsapi.plex.tv/v1.1/\" token=\"TOKEN\"+OQ=\" status=\"online\"/>\n <service identifier=\"subtitles-search\" endpoint=\"https://metadata.provider.plex.tv/library/metadata/matches\" token=\"TOKEN\"=\" status=\"online\"/>\n <service identifier=\"acoustid\" endpoint=\"https://acoustid.plex.tv/\" token=\"TOKEN\"==\" status=\"online\"/>\n <service identifier=\"lyricfind\" endpoint=\"https://lyricfind.plex.tv/\" token=\"TOKEN\"+/n5hMfGoF7PLEMPrLT9v/zqV1\" secret=\"H8q1AfgeOcf8+wx2ODos1mLBkmsSE4PMCJkkdx27xNwpzzKVV3up6gZJb+teyIOw\" status=\"online\"/>\n <service identifier=\"lyricfind-search\" endpoint=\"https://lyricfind.plex.tv/\" token=\"TOKEN\"+YgScsy+71q8J31KgROAuPkWvsus8XQuVFjYUiTjw5f+LesQ8MAgEcjnuYxW\" status=\"online\"/>\n </services>\n</user>\n",
"level": 4,
"time": "2020-11-24T18:11:40.518Z"
"level": 4,
"time": "2020-11-24T18:11:40.530Z"
"level": 4,
"time": "2020-11-24T18:11:40.537Z"
"level": 4,
"level": 4,
"time": "2020-11-24T18:11:40.542Z"
"level": 4,
"level": 4,
"time": "2020-11-24T18:11:40.543Z"
"level": 4,
"level": 1,
"time": "2020-11-24T18:11:40.544Z"
"level": 4,
"level": 4,
"time": "2020-11-24T18:11:40.551Z"
"level": 4,
"time": "2020-11-24T18:11:40.575Z"
"level": 4,
"time": "2020-11-24T18:11:40.580Z"
"level": 4,
"time": "2020-11-24T18:11:40.618Z"
"level": 4,
"level": 4,
"time": "2020-11-24T18:11:40.625Z"
"level": 4,
"time": "2020-11-24T18:11:40.626Z"
"args": [
null
"fragment": "",
"time": "2020-11-24T18:11:40.640Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.661Z"
"level": 4,
"time": "2020-11-24T18:11:40.671Z"
"level": 4,
"time": "2020-11-24T18:11:40.674Z"
"level": 4,
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.676Z"
"type": "ajax",
"url": "https://plex.tv/api/v2/features?X-Plex-Product=Plex Web&X-Plex-Version=4.43.4&X-Plex-Client-Identifier=j0iag2cctn5wiifp1qrhwaln&X-Plex-Platform=Chrome&X-Plex-Platform-Version=86.0&X-Plex-Sync-Version=2&X-Plex-Features=external-media,indirect-media&X-Plex-Model=bundled&X-Plex-Device=Windows&X-Plex-Device-Name=Chrome&X-Plex-Device-Screen-Resolution=2048x1010,2048x1152&X-Plex-Token=TOKEN&X-Plex-Language=en",
"status": 200,
"headers": {
"responseLength": 4957,
"time": "2020-11-24T18:11:40.680Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.682Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.690Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.693Z"
"type": "ajax",
"status": 401,
"headers": {
"time": "2020-11-24T18:11:40.695Z"
"level": 1,
"time": "2020-11-24T18:11:40.696Z"
"level": 1,
"level": 4,
"time": "2020-11-24T18:11:40.700Z"
"level": 4,
"time": "2020-11-24T18:11:40.701Z"
"type": "ajax",
"status": 401,
"headers": {
"time": "2020-11-24T18:11:40.702Z"
"type": "ajax",
"status": 401,
"headers": {
"time": "2020-11-24T18:11:40.707Z"
"level": 1,
"time": "2020-11-24T18:11:40.708Z"
"level": 1,
"level": 4,
"time": "2020-11-24T18:11:40.711Z"
"level": 4,
"type": "ajax",
"status": 401,
"headers": {
"time": "2020-11-24T18:11:40.713Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.720Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.724Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.729Z"
"level": 4,
"time": "2020-11-24T18:11:40.730Z"
"level": 4,
"message": "[Servers] Populate any server chose plex.tv where servers = plex.tv",
"level": 1,
"time": "2020-11-24T18:11:40.731Z"
"level": 4,
"message": "[Servers] Waiting for initial servers = [Bundled]",
"time": "2020-11-24T18:11:40.732Z"
"level": 1,
"time": "2020-11-24T18:11:40.778Z"
"type": "ajax",
"status": 200,
"headers": {
"level": 4,
"time": "2020-11-24T18:11:40.800Z"
"level": 1,
"message": "[Identity] [Bundled] and [Loopback] (cached) collide",
"time": "2020-11-24T18:11:40.801Z"
"level": 4,
"message": "[Identity] Merging [Bundled] into [Loopback] (cached)",
"level": 1,
"message": "[Servers] [Bundled] was removed",
"time": "2020-11-24T18:11:40.804Z"
"level": 4,
"message": "[Connections] Aborting all pending connection tests for [Bundled]",
"level": 4,
"level": 4,
"level": 4,
"time": "2020-11-24T18:11:40.805Z"
"level": 4,
"level": 4,
"time": "2020-11-24T18:11:40.819Z"
"level": 4,
"time": "2020-11-24T18:11:40.820Z"
"level": 4,
"level": 1,
"time": "2020-11-24T18:11:40.821Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.823Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.852Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.857Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.858Z"
"level": 2,
"time": "2020-11-24T18:11:40.859Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.875Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.886Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.904Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.909Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.917Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.925Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.935Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.942Z"
"level": 3,
"time": "2020-11-24T18:11:40.951Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:40.952Z"
"type": "ajax",
"status": 0,
"params": "{\"deviceIdentifier\":\"j0iag2cctn5wiifp1qrhwaln\",\"context\":{\"campaign\":{},\"device\":{\"product\":\"Plex Web\",\"version\":\"4.43.4\",\"platform\":\"Chrome\",\"platformVersion\":\"86.0\",\"device\":\"Windows\",\"model\":\"bundled\",\"screenResolution\":\"2048x1010,2048x1152\",\"layout\":\"desktop\",\"protocol\":\"http-loopback\"},\"user\":{\"anonymous\":false}},\"userId\":12952834,\"event\":\"client:switchuser\",\"interaction\":true,\"sessionIdentifier\":\"7a293d75-1e04-4e15-8d33-0625ce27d742\"}",
"time": "2020-11-24T18:11:40.958Z"
"level": 3,
"time": "2020-11-24T18:11:41.383Z"
"type": "ajax",
"status": 0,
"params": "{\"deviceIdentifier\":\"m9l2lkdb2bki7wzkw7c6cph5\",\"context\":{\"campaign\":{},\"device\":{\"product\":\"Plex Web\",\"version\":\"4.43.4\",\"platform\":\"Chrome\",\"platformVersion\":\"86.0\",\"device\":\"Windows\",\"model\":\"bundled\",\"screenResolution\":\"2048x1010,2048x1152\",\"layout\":\"desktop\",\"protocol\":\"http-loopback\"},\"user\":{\"anonymous\":false}},\"event\":\"client:view\",\"interaction\":true,\"properties\":{\"page\":\"home\",\"mode\":\"auto\",\"latency\":575},\"sessionIdentifier\":\"20e844ca-37a5-4a17-8ad7-ecaa8232a6b2\"}",
"time": "2020-11-24T18:11:41.548Z"
"level": 1,
"time": "2020-11-24T18:11:42.882Z"
"level": 1,
"message": "Cache overflow, size: 123",
"time": "2020-11-24T18:11:45.018Z"
"route": "webSettings",
"args": [
"general",
null
"fragment": "#!/settings/web/general",
"time": "2020-11-24T18:11:45.051Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:45.270Z"
"level": 3,
"time": "2020-11-24T18:11:45.347Z"
"type": "ajax",
"status": 0,
"params": "{\"deviceIdentifier\":\"m9l2lkdb2bki7wzkw7c6cph5\",\"context\":{\"campaign\":{},\"device\":{\"product\":\"Plex Web\",\"version\":\"4.43.4\",\"platform\":\"Chrome\",\"platformVersion\":\"86.0\",\"device\":\"Windows\",\"model\":\"bundled\",\"screenResolution\":\"2048x1010,2048x1152\",\"layout\":\"desktop\",\"protocol\":\"http-loopback\"},\"user\":{\"anonymous\":false}},\"event\":\"client:view\",\"interaction\":true,\"properties\":{\"pane\":\"web:general\",\"page\":\"settings\"},\"sessionIdentifier\":\"20e844ca-37a5-4a17-8ad7-ecaa8232a6b2\"}",
"time": "2020-11-24T18:11:45.357Z"
"level": 1,
"time": "2020-11-24T18:11:46.467Z"
"args": [
"debug",
null
"fragment": "#!/settings/web/debug",
"time": "2020-11-24T18:11:46.494Z"
"level": 3,
"time": "2020-11-24T18:11:46.502Z"
"type": "ajax",
"status": 0,
"params": "{\"deviceIdentifier\":\"m9l2lkdb2bki7wzkw7c6cph5\",\"context\":{\"campaign\":{},\"device\":{\"product\":\"Plex Web\",\"version\":\"4.43.4\",\"platform\":\"Chrome\",\"platformVersion\":\"86.0\",\"device\":\"Windows\",\"model\":\"bundled\",\"screenResolution\":\"2048x1010,2048x1152\",\"layout\":\"desktop\",\"protocol\":\"http-loopback\"},\"user\":{\"anonymous\":false}},\"event\":\"client:view\",\"interaction\":true,\"properties\":{\"pane\":\"web:debug\",\"page\":\"settings\"},\"sessionIdentifier\":\"20e844ca-37a5-4a17-8ad7-ecaa8232a6b2\"}",
"time": "2020-11-24T18:11:46.512Z"
"type": "ajax",
"status": 200,
"headers": {
"time": "2020-11-24T18:11:46.584Z"
"route": "logs",
"args": [
null
"fragment": "#!/logs",
"time": "2020-11-24T18:11:47.858Z"
They were both disabled i have posted above dosent make much sense to me? can you shed any light?
you probably need to capture what happens in the below log file, at the time that the folder error occurs
C:\Users\paul7\AppData\Local\Plex Media Server\Logs\Plex Media Server.log
(if you post a complete log - put it in a spoiler, or host it elsewhere. )
