Hi,
specs: opty 170, dfi nf4 sli dr, 2gig Gskill PC4000, zalman 9500led
Im currently running cpu at 2.5ghz primed it for 10 hrs and it was fine (I ran two prime test simultaneously)....ran memtest for 10hrs without any errors etc...
I overclocked the RAM and CPU using these settings:
FSB - 250
LDT - x4
CPU/FSB Ratio - x10
Vcore - AUTO
LDTv - 1.30
CHPv - 1.6
vDIMM - 2.6
DRAM Frequency Set - 200 (DRAM/FSB:1:1) Command Per Clock (CPC) - Enable
CAS Latency Control (Tcl) - 3.0
RAS# to CAS# delay (Trcd) - 04 Bus Clocks
Min RAS# active time (Tras) - 08 Bus Clocks
Row precharge time (Trp) - 04 Bus Clocks
Row Cycle time (Trc) - 07 Bus Clocks
Row refresh cyc time (Trfc) - 14 Bus Clocks
Row to Row delay (Trrd) - 03 Bus Clocks
Write recovery time (Twr) - 02 Bus Clocks
Write to Read delay (Twtr) - 02 Bus Clocks
Read to Write delay (Trwt) - 03 Bus Clocks
Refresh Period (Tref) - 3120 Cycles
Write CAS Latency (Twcl) - 01
DRAM Bank Interleave - Enabled
DQS Skew Control - Auto
DQS Skew Value - 0
DRAM Drive Strength - Level 7
DRAM Data Drive Strength - Level 3
Max Async Latency - 8.0ns
DRAM Response Time - Normal
Read Preamble Time - 5.0ns
IdleCycle Limit - 256 Cycles
Dynamic Counter - Disable
R/W Queue Bypass - 16 x
Bypass Max - 07 x
32 Byte Granularity - Disable(4 Bursts)
I am really worried about the temps because after priming both cpus simulateously for 10hrs the temps were as follows:
Loaded temps
cpu - 50
pwim - 55
Therefore I am concerned something is not quite right...and I could really do with some help to find out what??? questions I have are:
a) are those RAM timings - tighting or loosening the RAM? I believe they are tightening however whats better tigthening or loosening RAM?
b) what are safe temps for the opty 170?
c) Should I change those RAM settings? If yes what to?
I would really like to push this to the max and realise it will take time and patience which atm I have in abundance...all I am lacking is expert advise...
Please help
Thanks in advance...
Cheers....
P.S. Sorry for the lengthy post...I just wanted you guys to have all the facts...
FSB - 250
LDT - x4
CPU/FSB Ratio - x10
Vcore - AUTO
LDTv - 1.30
CHPv - 1.6
vDIMM - 2.6
DQS Skew Value - 0
Bypass Max - 07 x
Loaded temps
cpu - 50
pwim - 55
Please help
Cheers....
deff be higher.
. Normally, depending on air temps, this will do anything from 27-42C.
. The instructions certainly could be a little clearer - I had to look at the website in the end, which shows little gifs of air going in the front and out the back of the case.
