Pls help. What are these files? and can I delete them?
14 Aug 2003
cyberspace
Hi,
Found these files on my C: drive. Can anyone pls tell me what they are? And can I delete them? Using Windows 7.
install.exe
install
install.res.1028.dll
install.res.1031.dll
install.res.1033.dll
install.res.1036.dll
install.res.1040.dll
install.res.1041.dll
install.res.1042.dll
install.res.2052.dll
install.res.3082.dll
globdata.ini
install.ini
eula.1028.txt
eula.1031.txt
eula.1033.txt
eula.1036.txt
eula.1040.txt
eula.1041.txt
eula.1042.txt
eula.2052.txt
eula.3082.txt
vc_redist.msi
vc_redist.cab
globdata
they are installation files for Microsoft Visual C++ 2008 Redistributable Package you can delete them, or collect them up into a folder and keep 'em if you are likely to want them again.
Annoys me no end that MS can't get this installer to use the temp folder :)
Most of them do, but at least one redist is bugged and dumps the contents in the hard drive root (only encountered this with one game personally, which is Flatout: Ultimate Carnage).
annoys me even more the amount of different versions I have installed from various programs for the same damn visual library stuff
That's unfortunately the issue though, they are different. Applications and games that make use of Visual C require that the same version used during development is installed on the user's system, as they're unlikely to work correctly with a different version (either older or newer).
