Plug conversion help, please!
11 Sep 2009
Sister in law has bought a Xiaomi Roborock S5 hoover thingymabob and it's came equipped with a Chinese plug - I've tried a plug converter but it doesn't quite fit. I don't suppose anyone could recommend a converter that could help, please?
(if anyone could tell me how to upload an image :lolnoob: I could supply one)
ps. Happy birthday man
pps. Plug states 6A 250V
Not sure I'd trust leaving a robotic vacuum around when they can't even put a legal plug on the damn thing! Sounds like a recipe for disaster!
Just chop the plug off and fit a uk plug. Or is it some sort of all-in-one power brick type thing?
Wicked, thanks guys.
I'll chop the plug and fit a standard UK and a 3 amp fuse.
If the house burns down, I'll set up a GoFundMe.
Hi, I also bought a roborock s5 that came with 2 prong plug. I was going to use a travel adapter, but then noticed that its just a "figure 8 power cable"
https://www.google.com/search?q=fig.....69i57j0l7.7488j0j7&sourceid=chrome&ie=UTF-8
can be bought very cheap
I just used one i already had lying around, been running 1month+ no issues
Asked the sister in law about this, and the Mrs as I haven't seen the thing and you're right, it is a figure of eight - no plug cutting here.
:rolleyes: :p
Thanks everyone, you can all go home now :p
Aye with some of the cheap chinese crap I've seen even when they do have a UK 3 pin it didn't even have a fuse in it! Damn cable got bloody hot too pretty sure it didn't confirm to BS standards/unsafe/possibly illegal.
There is a lot of illegal UK plugs around unfortunately :( they gave us little credit card size gauges at work to check if the plug is legit, measures things like the pin and insulation depths etc and the dodgy ones are everywhere worryingly
I know what people mean about the cheap Chinese crap out there and to be careful, but the Roborock S5 isnt cheap by any means (approx £330) and is made by Xiaomi (A rather large company).
