Plug fuse question.
19 May 2012
Hi, I have bought an Onkyo surround speaker set but it came without a UK plug.
So I have ordered a new plug adapter but I don't know what amp the fuse should be.
It's only a 80 watt sub and on the back it say 50/60 Hz 20W.
Thanks.
Owned an Onkyo before, and the adapter was already installed. Some of them are simply an adapter without fuse, which was the one mine came fitted with.
Also mine was an active subwoofer and the subwoofer had the UK plug. Just the receiver needed the adapter.
