Plug my PS2 into my PC
2 Jun 2007
Mornington Crescent
Ideally I'd use PCSX2 to play the games on my PC normally, but unfortunately my CPU isn't powerful enough for some games, so I'd ideally like to be able to plug my PS2 into my PC and just record/stream what I'm playing onto the net. I know I'd need some sort of capture device, but what's the best? Ideally I'd like it to be pretty cheap, as its not going to get a ton of use, but I don't want a terrible picture either. There's no point spending some money on a piece of junk when a little more would get a much better quality.
I've had a little look around myself and found an Easycap USB for £4.57 which seems like it should do the job, as the PS2 cable I have does have the Red/white/yellow RCA cable selection for 2 audio and 1 video output. And its USB so it would be easy to keep it tidy. However, how good would the quality be over USB? And what else would you recommend?
Thanks!
Edit: Needs to work with Windows 7 x64!
Thanks!
USB2 should handle a SD stream fine, don't know about that hadware tho. There's USB2 Freeview HD devices so the bandwidth is fine.
