I have built my computer and everything, but want to make sure that I am doing it right with the gpu as the manual was not very clear. I have a seasonic gs 550w.
So I have two pci-e cable things which have a 6 pin and a 2 pin on like this:http://www.playtool.com/pages/psuconnectors/pcie6plus2.jpg
So do I plug the 6 pin and 2 pin cable into the power supply or is it just the six pin. On the power supply which looks like this
http://d.pr/i/YlAV
there are two 8 pin holes, I know I have to plug two cables in to each separate hole but do I plug the 6 pin one in or both and also if I only need to plug hte 6 pin lead in does it matter where I plug it in like on the left or right side of the hole.
http://d.pr/i/YlAV
