plugs, sockets etc.
27 Oct 2009
West Sussex
Hi all,
can anyone enlighten me with the names for the fan sockets and 3 pin plugs? same for crimping ends.
Was the pitch between the pins 2.5mm?
are there any 'official' names for these?
They are part of the molex family. Not sure about the pitch though.
Molex type kk.
Fan connector
The standard connectors for computer fans are
3-pin Molex connector KK Family
This connector is used when connecting a fan to the motherboard or other circuit board. It is a small thick rectangular in-line female connector with two tabs on the outer-most edge of one long side. The size and spacing of the pin sockets is identical to a standard 3-pin female IC connector. The three pins are used for ground, +12 V power, and a tachometer signal. Molex Part number of receptacle is 22-01-3037. Molex Part number of individual crimp contacts is 08-55-0101.
4-pin Molex connector KK Family
This is a special variant of the Molex KK connector with four pins but with the locking/polarisation features of a 3-pin connector. The additional pin is used for a pulse-width modulation signal to provide variable speed control.[6] These can be plugged into 3-pin headers, but will lose their fan speed control. Molex Part number of receptacle is 22-01-3047. Molex Part number of individual crimp contacts is 08-55-0101.
This connector is used when connecting the fan directly to the power supply. It consists of two wires (red/12V and black/ground) leading to and splicing into a large in-line 4-pin male-to-female Molex connector.
Dell, Inc. proprietary
This connector is an expansion of a simple 3-pin female IC connector by adding two tabs to the middle of the connector on one side and a lock-tab on the other side. The size and spacing of the pin sockets is identical to a standard 3-pin female IC connector and 3-pin Molex connector. Some models have the wiring of the white wire (speed sensor) in the middle, whereas the standard 3-pin Molex requires the white wire as pin #3, thus compatibility issues may exist.
Source
I bought some 3 pin fan, 4 pin fan, 24 pin ATX, 6 pin PCI-E and 8 pin EPS12V Orange connectors for my system but the site I got them from doesn't have Black in the 3 pin but they do in the 4 pin. There is however another site that seems to stock the Black ones but of course forum rules forbid me to mention them as they are a competitor.
I just googled 'Black 3 pin fan connector'
