Hi - I have moved into a 3-yr old house with a Baxi Combi 105e.
The problem is that when the radiators are switched on and the room thermostat is below ambient temp, the boiler will switch on and off all the time.
It will go "click, click, click" and the burners will ignite but then it immediately goes "click click click" and shuts down. This simply repeats over and over - I don't think it is right!
Other than that it is fine - tap water is hot and also the radiators get hot when the room thermostat is turned up.
Any ideas please?
Dave
PS I called Baxi and they said "You need an engineer. By the way we can send one for £225".
Any ideas please?
Dave
