Plumbers, TMV problem need advice.
12 Dec 2004
the south
Hey all
I fitted a cheapy thermostatic mixer shower/tap to the bath that's been working fine for the last two years.
Similar to this one. LINK
Last week the shower was only coming out lukewarm.
I tested some other taps in the house to make sure it wasn't a problem with the boiler and water is running red hot every where else.
Today I took the Valve cartridge out of the mixer tap to see if it was full of limescale.
Surprisingly it looked okay. I gave it a good wash and lots of black deposits came out of it.
Not entirely sure what they are, like small bits of grit but not sure if metal or not.
I soaked the valve cartridge in limescale remover to be sure and re-fitted it.
It doesn't seem to have made much difference.
There is also a thermostatic mixing valve under the bath in the most awkward position possible.
It's already set to the hottest setting.
I'm not sure if there is a problem with the tap valve cartridge or with the TMV under the bath.
Hoping it's the tap valve as the TMV is a nightmare to get to.
Also the tap valve is only a tenner.
So question is should I just replace the tap valve for a new one and see if that solves the issue.
Is there any thing else I should be checking?
If not and it turns out to be the TMV can I just remove it completely and run the hot and cold feeds directly into the tap?
The TMV under the bath is a pain in the arse any way.
photo for context.
Space is extremely limited. I can't even get my hand to the left side of the TMV.
Yep its a mess but that's how it was when we bought the house, I've not touched the pipe work only change the tap over for a new one.
I can understand why they've used push fittings, the photos don't really show how awkward it is to get at.
Using the shower this morning it was actually a lot better so it might just be a new tap valve is in order.
Are there any regulations for having a TMV?
It was a disabled lady who owned the house before us so guessing that's why it was installed.
Is there any reason why I can't remove it completely and just plumb straight into the tap, it would tidy the mess up.
