So I have been ripping out some plumbing and come across something boxed in, in what was my downstairs toilet room.
I have found a tall pipe coming off a join where the soil pipe from the old toilet runs into the ground.
It is a tall pipe, maybe 3 ft high, capped with a "S450 Air Admittance Valve 110MM" made by Hunter plastics.
Link here : http://www.hunterplastics.co.uk/media/3128/ws450.jpg?height=800 to what it looks like.
I have a couple of questions.
1. What purpose does it serve? It appears to have an air tight seal so not sure how it admits air. Also why is it needed, as surely the waste just runs down the soil pipe and away?
2. I no longer have the toilet in situ and the soil pipe has been capped at the old join from the toilet. There is a working sink which is still attached to the same soil pipe. Is it OK to remove the pipe with this valve and cap where it joins the main soil pipe, so that I just have the sink feeding into the main soil pipe and then two joins capped off, and are there any implications of me doing this?
3. If I ever re-instate the toilet, will I need to re-instate this pipe and what would be the consequence of not doing so?
Thanks in advance!
Thanks in advance!
