Hi
So I moved into a brand new house in November, the bath has always been luke warm despite the sink, right next to it being able to scald you after only a few moments of running the water.
So, Barratt send a plumbing/heating specialist to inspect it.
He mentions that the bath may have been plumbed in wrong and agrees with me that the water is simply not hot enough.
Defect inspection this morning as the house is approaching the end of its 1 year defect period and the inspectors mention that the Bath water will be on a valve and probably just needs adjusting. The whole bathroom is a total disaster and was clearly a Friday afternoon job. They are sending people to sort all the other bits but I want to fix this issue with the bath myself, or at least have an understanding of what to do to fix it.
Being impatient and keen to do things myself, I looked into this further:
- new building regs in 2009 mean that all baths must have a TMV.
- temperature of the water leaving the tap will not exceed 48'C
now, not exceeding 48'C and being nowhere close to 48'C are two very different things.
presumably this is to stop stupid people from boiling babies in hot baths, given that my house has zero babies to boil and is occupied by two competent grown ups, I think that myself and Mrs rjk are qualified enough to run a bath to a desired temperature without RoSPA's Hot Bath Water Safety Campaign interfering with our bath time agenda.
If I want to come out of the bath looking like a hairy lobster, then I bloody well will do.
My questions are as follows:
1. Is it just a case of turning the valve to adjust?
2. can you turn it so that it doesnt mix cold water at all?
3. If the answer to question 2 is 'no', can I have the TMV removed entirely?
Cheers
Cheers
