- 10 Sep 2003
- Midlands
I want to add a small sink into our garage for hand washing. My plan for fresh water is to T off an outside tap which should be easy enough, but i'm struggling with waste. Thankfully the waste inspection chamber is only about 3 meters away. How can I run my waste into the chamber (image below)? Can I just drill a hole through the black plastic at the side a couple of feet down and slope a 1.5inch waste pipe into it?
