plumbing help 3/4 to 22mm
18 Oct 2002
Hi,
for lack of a better word been shafted by plumber. Sitting here with no heating or running water and no professional help till Monday :eek:
Old suite is out, but its all old imperial pipe. Stuck some isolation valves on the 1/2in pipe (with the 5p trick) but the old bath tap pipe is 3/4.
Guy left his tools here so should have all i need, can't seem to get 3/4in isolation valves so how do i go about capping these or converting to 22mm?
Edit- ust like to say i would never normally touch someone elses tools, but desperate at the mo can see own breath in here!
Just buy a 22mm compression isolating valve and buy two 3/4" olives. Replace the 22mm olives with the 3/4" olives and job done :)
I was going to say that last time I really really needed a fix in a hurry, I found that a 22mm compression fitting will actually tighten down enough anyway. If you can get the 3/4 olives though it would be less likely to fail.
That is a leadloc mate, that is for 3/4" lead pipe which is much bigger. For lead pipe I think they measure the internal diameter and the pipe is usually quite thick.
Go down to your local plumbing shop, ask them for two 3/4" olives and a 22mm isolation valve. Ask them a cheap pipe cutter as well, something like http://www.wickes.co.uk/invt/500528 This one will adjust, so stick it over pipe tighten down and then turn it around the pipe, tighten a bit more and then turn again. Keep on doing this and the pipe will cut and you'll get a nice clean cut. Make sure though the pipe is round otherwise you will have issues.
He left you with no heating or water over the weekend? Yeeehaaaa ;)
My brand new CH install took 3 days, I had running water all days, was without heating for 1 day only. No water and no heating for the entire weekend is an utter ****take
I hope you're paying the cowboy in cattle or beans :p
Those compression fittings with olives are dead easy to use mate :)
You can buy Compression Fitting Straight Female Adaptor 22mm x 3/4 in most plumber merchants, like Plumb Centre, cost about £1;30p.
