- 5 Mar 2006
- everywhere
x
Easy enough two options use a 15mm pipe cutter cut out a section and fit http://www.screwfix.com/p/isolating-valve-with-handle-15mm/89226 or use and flexible hose with a valve built in thats a push fit onto copper pipe.
To fit a service valve to that you're going to have to cut the pipe so the best thing to do would be to cut it on the horizontal run and fit one of these - http://www.toolstation.com/shop/Plu...e+300mm+15mm+x+12+10mm+Bore/d20/sd2807/p30488
That way you have your isolating valve and it's easy to connect to the inlet valve for the novice
Edit; Pretty much as above![]()
