Plus.net Fibre
3 Jun 2005
West Sussex
Anyone else got this?
Fibre was just installed in my area so I placed my order with my current supplier Plus.net.
All went well and a very helpful BT engineer turned up first thing in the morning on the agreed installation date.
I un-boxed the Plus.net router I was charged £6.99 for and began reading (lucky I did) whilst the engineer was setting up.
He tested the line and then said it was over to me but I then realized a big problem, he had no Openreach Modem?
When I asked him he looked blank and said they have been obsolete for about a year but the instructions clearly stated I needed one.
The guy went out to his van and found a very used one which luckily worked.
Talk Talk etc all have all in ones, why is Plus.net using obsolete technology?
They supplied me with a Sagem 2704N.
Anyone else had this?
It isn't obsolete technology. The separate modem can be a better option as it allows much more flexibility if you want to use your own router.
If it really was an actual Openreach engineer then he's an idiot. It was quite possibly a third-party contractor.
Yep, down to Openreach to supply it. I would be contacting Plusnet about it, as you might have been given a knackered old one, when you should be getting a shiny new one.
It's not obsolete yet, but I'm amazed that Plusnet have not got an integrated option like most other large providers. Especially considering that the Openreach modems are (to the best of my knowledge) being withdrawn from new installs in January.
Thats my understanding. I could have configured my existing router with this set up but wrongly assumed I was getting an all in one.
I am not worried about the £6.99 just feel a bit miffed I had to order this.
We found that PlusNet and Gamma were probably the last few still to require modems as part of the install of their business packages. Gamma are phasing that out come the start of next month which is a bit of a bummer so we've stocked up on Modems as we've replaced them with Draytek 2860s
I'm hoping that the end of the Openreach modem means more suppliers have a go at making them. At the moment we have to buy DrayTek 130s and they aren't particularly cheap.
It's annoying because not only do UTM boxes have quite a high cost before they start having interface cards as options, the ones that support VDSL2 tend to be really bad.
Just having the opportunity to purchase the standard Openreach modems (preferably Huawei) without having to resort to auction sites would do me. They could just license someone to sell them.
That would do it. There are a few "router set to bridge mode" options but I very specifically don't want something that comes back as a router with Wi-Fi turned on when it factory resets.
Just chucking my 20p in, but it looks like Sky do the same as what the OP mentioned. I went to view a house on Friday which has BT Fiber, but I thought it was strange that they had a Sky router as well as a BT one?
Not really any more, for the past 12 months Sky have sent out the SR102 which has integrated VDSL modem (the black Sky Hub). They originally sent out their SR101 and then the install engineer (Kelly Comms / Quinns etc) would usually bring the BTOR Modem.
Can confirm this, recently had Sky Fibre installed and only had the SR102, they no longer use the BTOR modem :)
Openreach engineers are freelance (or the one I had was). I had plusnet fibre installed after moving house and got given another openreach modem despite already having one from a previous property. That was just over a week ago.
Dave
Dave
They're sub-contractors, usually Kelly Communications or M J Quinns and are different from the BTOR engineer(s) you get when there is a fault
Driving around moaning they're only getting £16 per install even though it often takes them 5 mins tops
Our open reach guy put a modem in which was new out of the box. This was in august.
I think if you take the router option its built in.
I was actually really impressed with our openreach engineer, really nice bloke. Only thing he grumbled about was that he could only get rubbish, less than 1mb adsl where he lived!
Separate modem works fine for me, I have a cat6 socket next to the phone socket and feed my network across that with the router in the cab in my garage.
Dave
