Hi
I have a new pc with these specs
Asus formula IV ROG
I7 3.6 ghz cpu
coolermaster haf xm case "with a lot of case fans"
Coolermaster seidon 240 M liquid cooler
G skill 16 gb ddr3 1600 mhz
7950 sapphire flex 3 GB
1050 w psu corsair
Intel 120 gb HDD SSD
And i have current set my cpu ratio to 44 x in bios and i cant go any higher to 44 = 4400 mhz but CPUZ only show me 4300 mhz in load, so i dont know why the cpu shows 4400 OC in bios.
Then if i try to ajust other options in the bios then i can clock the cpu higher, but then the ram also starts to gets OC to higer mhz and i have no clue what i am doing..i guess its OC when it comes to pro people
Now i set the bios to these 44 x multiplayer in order to get 4300 MHZ and these temps.
So i ned to know how can i clock my cpu to at least 4.6 ghz (4600) and is it a good thing to do with my specs..i mean with the temp..its around 65 in load..so how much could i push this new gear ?
please enlight me with some good clock setings. and how much volt cpu needs and stuff like that
http://i97.photobucket.com/albums/l230/Psycrow_2006/Idle.jpg
http://i97.photobucket.com/albums/l230/Psycrow_2006/Load.jpg
Hi
Asus formula IV ROG
I7 3.6 ghz cpu
1050 w psu corsair
