plz help me with a gaming pc
28 Sep 2008
nottinghamshire
hi all new to the site and must say what a brilliant place,been out of pc gaming for about 2yrs brought a xbox360 and a ps3 which i still sort of use and now i feel the need to get back to pc gaming and my what has changed since then.ok hope someone will have the time to help me out here.i would like to build a gaming pc never built one before but willing to give it a go,start of i have a 19" hd tv/monitor and keyboard mouse ect just need a base unit budget is limited really max i can pay or rather the wife can pay!! is around 700, less is best if possiable.
im a bit confused to what to go for now since my last pc which was amd 64+ sli with twin cards and dual core ect brought that from wired2fire for a mere 1100pounds.
im open to ideas to what setup to have whether is sli or not just want a gaming pc that will last and be future proof for a year or so,even better if i can play crisis on full wack and i also play mainly fps games!!
will require a windows system as well so if someone can do me a shopping list for that shop i would be so happy then i can walk up road and order the parts.if you can put the links to each item that would be great if not just type them out and i will find them on there.
cheers for your time.
welcome
CLAIMED :)
If your looking for a gaming pc,i will make a spec up but with links from ocuk so you know what they are .
you only have a 19" monitor so a 4850 wil be fine.
Remove the competitor link.
+1 to the spec above. Would be perfect for your needs. :)
Although the RAM is a bit overkill, go for some decent pc2-6400, that would still let you overclock fine.
