[plz help] Questions about the U2311H signal support (to connect consoles)
13 Jan 2011
Does the VGA/DVI port of U2311H support or compatible with Component/YPbPr signals ?
I need to use this cable with my monitor:
http://www.ebay.com/itm/VGA-SVGA-RCA-Component-Video-Converter-Cable-Adapter-/270716072962?pt=LH_DefaultDomain_0&hash=item3f07ef7402
or this cable in case of dvi:
http://www.ebay.com/itm/DVI-I-M-RCA-VIDEO-Component-ADAPTER-HDTV-ATI-NEW-/220824991437?pt=LH_DefaultDomain_0&hash=item336a31f6cd#ht_3103wt_1801
*note that this is dvi-i and the u2311h has just dvi-d so i dont sure.
The main goal is to get the best picture quality from a PS2 console that connected with an A/V Multi out with composite or A/V Multi out with Component:
and i saw another possibility with this cable:
the question is that i dont know if the VGA port of u2311h support RCA/S-Video input signals.
any suggestions? what do i need to get the best quality for the PS2 (any cables /adapters or anything) :)
