plz help
1 Oct 2010
okay so i have just got a new 780 i had no problems before everything was going well till lastnight then when i booted up my pc the loading screen went crazy see the photo i restarted a few times and still the same so i set my bios too default and nothing then i refreshed my pc and got on in the end i did a clean install and everything was going well then after a few hours i was watching a program and my pc just kept powering off after say 5mins or so then today i am getting the same crazy loading screen plz help
When I added a 290 into my x58 system. It really didn't play nice.
What speed are you running your ram and CPU? If you're overclocked, back off and go to stock. Load optimised defaults or fail safes.
Triple check the graphics card is seated properly/plugged in properly. Make sure nothing else has been knocked loose.
