plzzz recommend a psu for a nf7-s socket mobo
17 Apr 2007
I'm having a problem with my nf7-s socket mobo, i have a feeling its the psu so i need a good quality psu very quiet and if that isn't the problem with my nf7-s board i will be using the new psu for a new system i'll be building the new system will be a q6600, p5k-e wifi, geforce8800gtx and at least 4 or 5 HD's so i need the psu to work on both systems so if it doesn't fix the nf7-s problem i need it working on the new system
Look at these.
They dont make much noise and have plenty of oomph.
You'd prolly get away with a 520 as hard disc are not that demanding.
I know these come with a 24 pin ATX and the NF7 is 20, but you dont use the 4 at the end.
Like this
The ATX connector on the HX620 is native 24-pin. However, as you can see above, a small block of 4 connectors can be broken off to switch the connector to 20-pin, and thus make it compatible with older motherboards.
That Corsair has a 4-pin connector as well as an 8-pin connector redknight. And with the main 24-pin being splittable down to a 20-pin, it is pretty much guaranteed to work with your board.
