PnP Driver not found
EP3
EP3
31 May 2009
I'm having trouble trying to install a zyxel modem on the new pc. I keep getting this error. The modem is 4 years old and I can't find any reference to relevant drivers on zyxel's site...
Any help is greatfully appreciated!
:D
Well you'll need to find some because it won't work without drivers.
If it's gonna take you more than an hour or so of searching you might aswell buy a new modem, they're not expensive and it'll probably work better.
What OS are you using and what is the actual modem?
If it's a USB ADSL modem and the OS is something like Vista 64 you may be unlucky.
My first stop when looking for drivers that I can't find on the manufacturers site is usually to google the modem make/model and OS.
Thats it exactly - adsl usb and vista 64..
just found out that they are not doing drivers for 64 bit
new modem needed!
:rolleyes:
