Pocket Money upgrade question
12 Jan 2012
Wallington near Croydon
Hi all, been a while since I posted...
Just built one of my sons a modest gaming rig out of spare parts I had following an upgrade to my own system.
His main interest is in playing GTA V at 1080p, which this system can do after a fashion.
The system I've built him has :
AMD Phenom II 1045t CPU (6core 2.7Ghz)
RADEON 5850 GFX 1GB
6 GB RAM.
He's already looking at what he can save his pocket money toward to provide budget upgrades. The current mobo will only take Phenom chips as a max but I have another I could swap out which will take the FX Range.
So what I'd like some advice on is should he upgrade the CPU (thinking to a FX 8320) or the GFX card first?
Any advice appreciated, if he needs to look GFX 1st, what 2GB minimum card will give him a noticeable boost for £150?
Thanks!
You'd be looking at a GTX970 or an R9 270 depending on preference for that price.
I'd be looking at saving for a bit longer and getting a 4GB card though, get him to wash your car a few times :-)
Andi.
What motherboard is it? What make and model psu does he have? The gpu would give the biggest immediate boost.
Current is a ASROCk N68C-S UCC but I can swap it out for a Gigabyte GA-78LMT-USB3 which has better CPU support.
Can't remember the PSU model but it's a 500w Antec.
Andi.
As well as the 970 being actually the 960 as pointed out, the 270 should probably read 380 being the AMD offering around the £150 mark.
Thanks all, so there seems to be agreement that GFX is the way to go 1st of all??
Given that he'll take a couple of months at least to save the required cash it's probably I take a look closer to the time in the hope that some of the even more capable cards have dropped to around £150 by then.
