PoE enabled Homeplugs?
27 Nov 2005
Edinburgh
Hey does anyone know if you can get a PoE enabled Homeplug? I want to be able to run Ethernet to an outdoor PoE IP cam and if I can combine PoE and a Homeplug into one unit it would mean I would only need one power socket for the camera. I know that Logitech do a specific bundled package (Alert 700/750) which has this, but I can't find any stand alone plugs..
Cheers
im not aware of such home plug but i have not done any reasearch but you could easily add a poe injector to the end of the secound home plug
But this would require 2 power sockets still which would defeat the point in using the PoE feature in the first place :/
You could use one of the adapters that passes the mains socket through to the front. They're slightly more expensive, but you'd only need a single socket.
Also the Alert adapters you mention in your original post appear to be easily available as a Logitech spare part.
