13 Mar 2017 at 23:52 #1 Scream Scream Soldato Joined 18 Oct 2002 Posts 4,656 Location The Darkside Just wondering have any of you lot used a Poe extender? They seem to claim you can get another 100m run from using one. Too good to be true or the real deal? If you have, what's your opinion and what one did you use?
13 Mar 2017 at 23:57 #2 bledd bledd Don Joined 21 Oct 2002 Posts 46,834 Location Parts Unknown Just like using a switch I guess. Should work fine.
14 Mar 2017 at 00:05 #3 Caged Caged Man of Honour Joined 18 Oct 2002 Posts 26,753 Microsemi (Powerdsine) would be my go-to for PoE stuff https://www.microsemi.com/products/poe-systems/poe-extender
14 Mar 2017 at 00:18 #4 Scream Scream Soldato OP Joined 18 Oct 2002 Posts 4,656 Location The Darkside I was intrigued with the fact that they don't need powered by a local source but by the original Poe power you want to extend. Thought it would be a good way to power a Poe switch or camera nearly 200m away.
14 Mar 2017 at 10:08 #5 bledd bledd Don Joined 21 Oct 2002 Posts 46,834 Location Parts Unknown Ah, I was thinking it was a 2 port powered switch. I've not used what you're talking about.
14 Mar 2017 at 10:40 #6 Sp00n Sp00n Soldato Joined 18 Oct 2002 Posts 18,296 Location Brighton It's legit, just check the quoted wattage/distance figures to make sure you'll be alright.
15 Mar 2017 at 06:38 #7 Steveocee Steveocee Soldato Joined 5 Nov 2011 Posts 5,599 Location Derbyshire I've used a product by Veracity for this, used 2 actually as the cable run was about 280m. They've worked flawlessly since going in.
