Hi
I have got some POE Injectors and i am running them with a Tenda W301A on a netgear router, The Tenda W301A power adapter fits fine in to the end of the poe but the end that goes in to the access point didnt. i went to maplins and got a new end and soldered it on and it now fits fine.
for some reason i cant get power to the Access point at all. Voltage is going to the end with a multimeter but the access point just wont power. Could i be doing something wrong. are the injector kits rubbish?
Thanks for any help in advanced.
