I have a router on the top floor that feeds into 2 switches,one switch supplies ethernet feeds for the front of the house ,the other switch supplies the back of the house.
If I add a PoE injector for an IP camera to an ethernet cable that ports onto either of the switches are there any issues I should expect to encounter or are there any other complications I can expect from this kind of set up?
I guess everything should be ok but it doesn't hurt to ask before the fact either.
Cheers.
Cheers.
